08-18-2015, 12:41 AM | #1 |
Rock Stacker Join Date: Feb 2014 Location: Arvada
| Axial Extended / Longer Body Post Solution
After an extensive search on forums and the internet, I was unable to come up with a single company that offered extended axial body posts. But, I found a simple solution while searching ebay. I ordered a set of Vaterra VTR230006 body posts. They are considerably longer as you can tell compared with a stock SCX10 post. But they do not have the identical shape. After a few mins on a bench grinder, shaving the semi flat sides, they fit perfectly. Plenty of length left below the mount for strength. I do not recommend trying to shave these down by hand.... |
08-18-2015, 09:16 AM | #2 |
Rock Crawler Join Date: Mar 2006 Location: Dogpatch
| Re: Axial Extended / Longer Body Post Solution
Nice solution.
08-18-2015, 10:44 AM | #3 |
Great idea and they seem to be made of better plastic. You could also drill out the shock hoop body post holes, but that might make already weak shock hoops weaker? I've broken the little piece off the top of SCX shock hoops where the little post retaining clip goes, could redrill that hole lower in the shock hoop where there's more plastic too.
08-18-2015, 11:11 AM | #4 |
Quarry Creeper Join Date: Aug 2013 Location: Wijnandsrade, NL
Nice solution and well worth remembering! What body is goin on there and what will it do to the centre of gravity?
08-19-2015, 12:07 AM | #5 | |
| Re: Axial Extended / Longer Body Post Solution Quote:
The Vaterra posts do seem to be noticeably stronger and more durable plastic, an upgrade in itself. But after shaving down the sides, it fits very snug but still slides in and out. By installing these, there is no need to drill or modify anything else. | |
08-19-2015, 12:11 AM | #6 | |
Putting the body a little further in the air doesn't affect the center of gravity any noticeable amount. Much more advantageous to keep the body slightly higher, and reduce the preload on all of the shocks. I run my front shock preload a considerable amount lower than the rears to help with crawling up steep rocks. The extra 2-3 hole positions helped out a great deal. | |
06-17-2017, 05:43 PM | #7 |
Newbie Join Date: Mar 2014 Location: Klamath Falls
When you say longer, how much longer are you talking about? I am trying to fit a J Concepts 1974 Bronco on my SCX-10 and it looks like I need at least 2 more inches in the back. Thanks |
Axial Extended / Longer Body Post Solution - Similar Threads | ||||
***Giveaway - Axial AX-10 Lockers - The Solution*** | TylerV | Axial AX-10 Scorpion | 185 | 05-25-2008 09:38 PM |
2.2 Axial beadlocks-hex stripping solution? | racenut123 | Tires and Wheels | 14 | 09-09-2007 09:50 AM |
