08-21-2015, 04:57 PM | #1 |
Rock Stacker Join Date: Dec 2011 Location: Atlanta
| MIP shafts for axial dingo?
what MIP shafts will fit an axial dingo? i bought MIP #10145 because it said it would fit all Axial vehicles except for jeep Rubicon. but they are too long.
08-21-2015, 07:10 PM | #2 |
| Re: MIP shafts for axial dingo?
The approximate drive shaft length range for the Dingo is: 82-117mm Rear 95-130mm Front One approach is to cut down the MIP shafts to the right lengths. Another approach is to get the Dig shaft male shafts, Wraith coupler, ax10 couplers and Traxxas #5145 pins to do a mix and match to get working size. Non MIP solutions: Junfaq J90025 Shafts Traxxas Max Shafts: Traxxas 5MM HD - Maxx Drive Shaft Yokes Traxxas Maxx Drive Shafts - Heavy Duty |
08-21-2015, 07:14 PM | #3 |
| Re: MIP shafts for axial dingo? |
08-21-2015, 07:50 PM | #4 | |
| Re: MIP shafts for axial dingo? Quote:
If not then I would get : 2 or 3 ea. MIP C-Drive Hub 5mm, Axial AX10 (1) #08112 (Not required but gives you use the Traxxas pins with the 2mm heads.) I buy the AX10 set for all my rigs and buy the longer Wraith hub as needed. You will also need 2 short male shafts. 2 ea. MIP Spline CVD™ Male Bone Short, Traxxas E-Revo (1) #08139 1 or 2 ea. MIP 5mm Drive Hub, Long, Axial Wraith #11117 Don't forget the traxxas pins Traxxas #5145. They fit into the AX10 drive hub and replace the set AX10 set screws. A little grinding maybe required on the short male shafts to get to right length. You will have to try the various combos of drive hubs to get the right lengths for your setup. If too short you can use two of the longer Wraith hubs. | |
08-21-2015, 07:57 PM | #5 | |
08-21-2015, 08:55 PM | #6 |
Yes, lots of good info in this one. Thanks K7! |
09-20-2015, 06:41 PM | #7 |
RCC Addict Join Date: Jun 2006 Location: Durham, NC, USA
...so.....the MIP #08101 fits the Dingo without any mods...right?
09-20-2015, 07:00 PM | #8 |
Rock Stacker Join Date: Jun 2014 Location: Middle of No where
Yes that's what I'm running no mods needed expect for maybe clearancing the spur gear cover
