09-09-2015, 08:06 PM | #1 |
Rock Crawler Join Date: Mar 2015 Location: "Crawling Heaven"
| What did you do with your scx10?? This is my scx10 bronco. Aluminum links Steel gears 4 link front and rear 55t 2s 4000mah ae-5 Pitbull rockbeast on axial 8 hole wheel Edit: new front shocks! _______________________________ Scx10 Bronco aka The Bronco Last edited by Bmxreeves; 09-11-2015 at 01:46 PM. |
09-10-2015, 06:14 PM | #2 |
Quarry Creeper Join Date: Sep 2010 Location: Big hands, Little tools.......GRRRRR
| What did you do with your scx10?? Got angry at the JK so I pulled out the trusty unused honcho. Beep Beep Beep Bee Bop Boop Beep |
09-11-2015, 12:04 PM | #3 |
| Re: What did you do with your scx10?? |
09-11-2015, 12:53 PM | #4 |
Quarry Creeper Join Date: Aug 2013 Location: Wijnandsrade, NL
To prevent this thread going Facebooklike with lots of flexpic's etc. Just one pic. To answer the question in words: I've build them. Both the G6 and the Rubicon. Made presentation pics and a showcase video of them whilst brandnew and scratchless. Then i started driving them to hell and back. As soon as they came back, i've send them out again. Rubicon: running dual Novak Terra Claw's 35T with both 16t pinions on a metal 87 spur (no clutch, fixed). Lifted the chassis with 105mm GMade Zero's. Replaced the front 3 link by a 4 link. Running steel driveshafts. Running 2.2 RC4Wd Dick Cepec's mud countries. Hated them at first. But after many miles and plenty of usage they get better and better. They outperform my mudslingers with ease... Powered by 2S. Never felt the urge to go 3S. G6. Running single Novak Terra claw 35T, 15t pinion on 87 metal spur. Also no slipperclutch. Installed a liftkit because of the (at first) installed 2.2 Proline flatIrons. This is my workbeast and has seen way too much action. Survived lot's of rollovers (some 33 feet on hard rock). Stood parked in the sea (salt) for a photosession and survived it (except for the tirefoams). Still - they survived all the abuse - running the stock Wildboar drive shafts... Has been submerged more often then an average SSN-774 class submarine . A picture of her in full action decorates my livingroom in honour of, size 4 feet wide . |
09-11-2015, 01:42 PM | #5 |
09-11-2015, 01:44 PM | #6 | |
| Re: What did you do with your scx10?? Quote:
09-11-2015, 01:47 PM | #7 |
Newbie Join Date: Aug 2015 Location: Somerset
Built some homemade link tabs....homemade acle tube inserts and getting ready to fab a new front stinger. Smaller then the one on her now Sent from my LGLS990 using Tapatalk |
09-11-2015, 01:56 PM | #8 |
09-11-2015, 08:41 PM | #9 |
Pebble Pounder Join Date: Feb 2015 Location: Carson Valley
09-14-2015, 07:26 PM | #10 | |
RCC Addict Join Date: Jun 2006 Location: Durham, NC, USA
| Re: What did you do with your scx10?? Quote: | |
09-14-2015, 08:43 PM | #11 |
Rock Crawler Join Date: May 2009 Location: Texas
09-14-2015, 08:48 PM | #12 | |
09-15-2015, 02:06 AM | #13 |
Newbie Join Date: May 2015 Location: Atoka
I bought the axial g6 I didn't do much to it at first I just drove until something broke. The first thing I noticed was the steering linkages real flexible and weak as well as the suspension linkage. Somebody posted a video on here and I watch a guy make his suspension linkage out of all thread rod and aluminum tubing. I decided I wanted to do the same thing instead of aluminum tubing I used 8/32 all thread rod and 7/32 x .014 brass tubing. While I had everything tore apart I went ahead and took the steering linkage off and made a new steering arm and servo arm. I also removed the wishbone from the front axle removed the connector on the axle. In the spare parts bag was another linkage connector for the rear axle, I put it on the front axle and made new linkage arms for those it now has true four link suspension front and back. The only other thing I've done to mine is strapped a couple of LiPo batteries to the sides put all the electronics in a small electronics box located above the steering servo. I'm thinking my next step is to go with a waterproof ESC and a decent motor and transmission upgrade. Then the I want to get a body and some 2.2 wheels and tires. It was awesome to take it apart and build something with my own two hands to put it back together better than before. Sent from my Z987 using Tapatalk |
What did you do with your scx10?? - Similar Threads | ||||
Newbie. Ordered CRC ScX10 rtr and SCX10 jeep kit. | Mattdaddy1974 | Axial SCX-10 | 15 | 07-11-2015 02:50 PM |
