09-13-2015, 07:38 AM | #1 |
Rock Crawler Join Date: Aug 2015 Location: Fort Knox, Kentucky
| Can someone explain these D60 axles to me?
So all the stock gearing/internals/hubs etc.. go directing into these?
09-13-2015, 07:39 AM | #2 |
Quarry Creeper Join Date: Jun 2013 Location: Australia
| Re: Can someone explain these D60 axles to me?
What is it that you want to know?? Sent from my iPad using Tapatalk |
09-13-2015, 07:39 AM | #3 |
Quarry Creeper Join Date: Jan 2012 Location: winder, ga
yes.
09-13-2015, 07:41 AM | #4 |
Correct. All is it a more scale looking axle housing. You swap all your axle drivetrain and steering components over to new axle housing. |
09-13-2015, 07:53 AM | #5 | |
| Re: Can someone explain these D60 axles to me? Quote:
Thanks! Would I need to change anything with the steering linkage? | |
09-13-2015, 08:11 AM | #6 |
Rock Crawler Join Date: Jul 2012 Location: Grand rapids
I got my set, and it's worth it if you would like a more scale axle and not wanting to spend a lot of money.
09-13-2015, 10:29 AM | #7 |
| Re: Can someone explain these D60 axles to me? |
09-13-2015, 02:03 PM | #8 |
It's not just for better scale looks fellas. These SSD housings are designed and manufactured better in every way. Thicker wall tubes with more durable material. Easier access to the the diffs. Smaller outer proportions for more clearance everywhere, and yes, they look a thousand times better than the stock axles. These are an upgrade in performance as much as looks.
09-14-2015, 06:01 PM | #9 | |
I wanna be Dave Join Date: Dec 2006 Location: Where the sheep run scared.
09-14-2015, 07:20 PM | #10 |
Newbie Join Date: May 2015 Location: USA
Don't forget to order the SSD servo plate if you want to mount your servo on the axle like stock. Sent from my iPad using Tapatalk |
09-14-2015, 10:11 PM | #11 |
Newbie Join Date: Aug 2014 Location: Nortonville Ky
The tubes are way better than stock and they look way better than any other plastic SCX housing that I know of. I don't regret spending $55 on mine at all.
09-15-2015, 06:57 AM | #12 |
Quarry Creeper Join Date: Feb 2012 Location: Verdi, Nevada
Took mine wheelin on a good session. Love them. The servo plate is the only thing you need if your not CMS. Way easier work on,and look great. SSD did A real nice job
09-15-2015, 01:09 PM | #13 |
Rock Crawler Join Date: Jul 2015 Location: Butler, Pa
a just bought a set at LHS and noticed after I got home that they don't work with the 3 link set up. You will have to change over to the 4 link set up.
09-15-2015, 01:23 PM | #14 |
Sir they will most defiantly work with the 3 link. They might not bolt right up to your current or attempted set up. With this hobby most anything is possible. A 3 link requires proper link placement etc. You can't say that the housing will not work with 3 link. The statement is ridiculous I had to edit my reply because my new lipo wont work....... The damn thing has a traxxas connector and my esc has deans??? What to do now... Last edited by Bananaclip; 09-15-2015 at 01:53 PM. |
09-15-2015, 08:54 PM | #15 | |
I was talking about the stock axial 3 link mount that comes with most SCX10 kits. yes you can make a 3 link setup work with added work but as for using the axial stock plastic 3 link parts they wont bolt right on to the axles without mods being done to make them work. seems like the author who asked the question was looking for direct fit parts without mods being made to part. if you have done a 3 link using the stock axial parts please post up some pics to help everyone along also if you need help with that connector let me know I can solder you up some new connectors of your choice better yet let me take an extra 15 minutes to show you how to solder up your own connectors | |
09-15-2015, 09:01 PM | #16 |
You need a 4 link anyway! |
Can someone explain these D60 axles to me? - Similar Threads | ||||
T-rex D60 axles vs axial axles | polaris98 | 2.2 Scale Rigs | 1 | 07-15-2008 08:44 PM |
new rc4wd d44 and d60 axles | SUPERCLODBUS | General Crawlers | 0 | 05-27-2008 03:40 PM |
