Thread: 2009 SCX10 Re-Do... "Ratchet"
Old 09-23-2015, 08:29 PM   #1
Default 2009 SCX10 Re-Do... "Ratchet"
So I am almost done with my rebuild using the Deadbolt body.
Today all electrical and mechanical work is completed. All that is left is cosmetic including 1.9 steel wheels from SSD on back order and 1.9 KLR's.
I will organize some pics for posting later.
Thus far I have incorporated;
-SSD D60 axles
-SSD 1.9 steel wheels
-Sense engine sound system
-Savox wp servo
-RC4WD CMS
-Pro-line scaler shocks
-STRC rear lock-outs and front steering knuckles and hubs
-Yeti BL esc
-Novak 35t crawler motor
-Toyzuki front motor mount
-VP gear box housing
-Deadbolt body
-CC BEC
-Traxxad 4ch rx/tx
-3Racing winch
-Maxamps 11.1v 2250mah battery side mounted
-Axial tail lights, roof lights and head lights and 2 simple LED controllers
-Custom Bronco grill
V
Bringing the pain since 1968
Vengeance is offline   Reply With Quote
Old 09-23-2015, 11:58 PM   #2
Default Re: 2009 SCX10 Re-Do... "Ratchet"
Whoooo Hooooo! KLR's ordered!!!
Old 09-24-2015, 08:37 AM   #3
Interested to see this one. How do you like the Toyzuki motor mount? I've got my battery and ESC up front. Wondering if it's worth it to rearrange everything.
SCREAMER is offline   Reply With Quote
Old 09-24-2015, 10:27 AM   #4
I am going to run the truck a little today.
The weight bias is on the front side, but I am also running a SSD front bumper.
The install was a piece of cake.
I am running a short MIP driveline from the spur gear shaft to the tranny then just WB drivelines to the axles.
The truck turns very well and does great donuts and drifts planting the inside front tire as the axis point. I know that has nothing to do with crawling but it couldn't do that before.
The battery is a Maxamps 2250mah 11.1v tucked on the side of the tranny.
It seems well balanced and doesn't want to tip over until past its true vertical now.
I'll post pics later time permitting.
V
Old 09-24-2015, 09:17 PM   #5
Ok so today I added a spare wheel/tire to the cage and did a little test driving.
To be honest I did not think it would do too well with the 1.55 Pitbull Growlers however, it did fantastic.
I cut the front tires and vented them so they conform to obstacles and only did a trim to every other lug on the rear tires' sidewalls.
It is handling wonderfully, better than expected. The front motor mount really improves the handling.
Here are a couple pics... still have some items to finish regarding cosmetics though.
Old 10-16-2015, 10:31 PM   #6
LOL, I forgot I had this thread...
I posted some pics in another thread now that it is finished.
Here are 2 images of the completed rig.
2009 SCX10 Re-Do... "Ratchet" - Similar Threads
Jeep WK "Grand Cherokee" SCX10. Episode 1 "Rescuing Megan" - Extended Trailer Spidernad Scale Videos! 7 04-22-2014 07:08 PM
Jeep WK "Grand Cherokee" SCX10 - Episode 1 "Rescuing Megan" - Full Video Spidernad Scale Videos! 4 11-12-2012 11:23 AM
