Thread: Wraith axels on Scx10
Old 10-10-2015, 01:45 PM   #1
Default Wraith axels on Scx10
Hi guys.. I need some help
I have run my Scx10 with the Vanquish Curry axels.. and I’m pretty pleased with this setup.. But i like the width of the Wraith axels, so i bought the new hardware to rebuild the axels to Wraith.
I knew the links was going to be a problem, so I wonder if there are any link kit`s available for purchase. Preferably TI links..
I would really appreciate your help
Tom
TomSo is offline   Reply With Quote
Old 10-10-2015, 02:47 PM   #2
Default Re: Wraith axels on Scx10
I wish there was seeing that not everybody has the capability to make their own links. But you're going to have to make your own or figure out what length pre-made links you'll need. Search "wroncho" for info on this set up.
SPLATT is offline   Reply With Quote
Old 10-10-2015, 02:51 PM   #3
Get a set of the wroncho plates well worth the 30.00 they cost from a vendor from here.
rickrob is offline   Reply With Quote
Old 10-10-2015, 03:28 PM   #4
Thanks guys..
I will look into the wroncho plates.
I will try to figure out the lengths for the links also..
Is there a good place to buy the TI rods ??
Sent from my iPad using Tapatalk HD
Old 10-10-2015, 06:08 PM   #5
I searched wroncho's looked at what everyone was doing and built one. I really like how it turned out it's one of my favorite rigs to drive.
k goodrich is offline   Reply With Quote
Old 10-13-2015, 01:08 PM   #6
+1 on todbldz's Wroncho plates. They are great even if you don't put them on a Wroncho build. I have 2 sets and they are versatile, well made, and cheap. On SCX10 style axles they give you good anti squat and enable you to dial in the pinion angle quickly and easily. On a Wroncho build they also let you clear the driveshafts and because of the abundant choice of upper link mounting options you can easily reuse the links you already have and still have the correct wheelbase and ideal pinion angle. I've noticed how many of the new aftermarket chassis rails are incorporating more upper link mounting options. It's just a good design and really increases suspension tuning options.
SCREAMER is offline   Reply With Quote
Old 10-13-2015, 05:05 PM   #7
Here is a link to my Wroncho build on SBG, hope it helps you out. I used a GCM racing SCX10 front mount conversion to eliminate all of the binding issues.
Wroncho Punisher..
WraithVader is offline   Reply With Quote
Old 10-13-2015, 05:15 PM   #8
Jmo but wraith axles are to wide for a proper scale rig.
Bananaclip is offline   Reply With Quote
Old 10-13-2015, 05:30 PM   #9
The only issue is the bottom links hitting the drive shafts. I used a high clearance link and a couple angled rod ends to clear mine. If you keep your axle outputs in line with the output of the trans and clock them up you will be better off and you won't have those crazy drive line angles to deal with.
Stuck is offline   Reply With Quote
Old 10-13-2015, 08:20 PM   #10
or you could do this:
Mike Flea is offline   Reply With Quote
Old 10-14-2015, 04:12 PM   #11
JMO, but SCX10 axles are too narrow for proper performance.
