Thread: SCX10 IFS - Chevy (Clod Based) Prerunner
Old 10-26-2015, 08:33 PM   #1
Default SCX10 IFS - Chevy (Clod Based) Prerunner
So I got a little bored with my 1.9 IFS IH Scout and saw this cool white late '70's Chevy prerunner and got hooked. So I made some lower trailing arms added some Proline Trencher tires on 2.2 wheels for mock up, picked up a Clodbuster body and a cool 3D printed front grill assembly and started a little build. Have a couple of King 110mm shocks for the rear, and started the body mods.
Used HPI RS4 front suspension parts, Blue Monkey front spool, matched Axial gear set, inverted the rear axle to match the HPI front rotation. Front bumper is from the Scout, hasn't been modified for the Chevy yet.
Its a start......
Inspiration
The chassis
Test fit the body to check stance
[/URL]
Started to section the rear quarter panels so I could move the wheel well lip to the outer edge. Started the quarter panel extensions, and the front fender flares
And the grill
joe122 is offline   Reply With Quote
Old 10-27-2015, 03:38 PM   #2
Default Re: SCX10 IFS - Chevy (Clod Based) Prerunner
Wow! I like how this is coming along. I will be following this one for sure.
Prime is offline   Reply With Quote
Old 10-28-2015, 08:46 PM   #3
Had just enough time tonight to finish most of the styrene mods. Started some shaping, almost ready for filler. Have an idea for some inner wheel wells.
Old 10-28-2015, 10:48 PM   #4
~THE SCALE SHOP~
o hell yes
STANG KILLA SS is offline   Reply With Quote
Old 10-29-2015, 01:56 AM   #5
That's definitely badass!!!!!
Sent from my 2500HD
rocpede is offline   Reply With Quote
Old 11-04-2015, 06:10 PM   #6
A little more progress. Got the first coat of primer on, a lot of spot filler sanding left to do. Started on the rear cage, shock mounts, battery cover. Ordered a set of Crawler Innovations 2.2 6 holes, with there negative offset, I am hopping to get a little more "tuck" in the rear tire setup. Still more tube work to go.
Old 11-04-2015, 08:52 PM   #7
gosh dang it man she is beautiful
big bacon is offline   Reply With Quote
Old 11-04-2015, 08:56 PM   #8
oooooo..... very cool build for sure. that body work is great and looks mean.
Szczerba is offline   Reply With Quote
Old 11-04-2015, 09:28 PM   #9
In some pics you have a cantilever rear suspension... I take it your not using that setup. I love the build. So cool to see what can be done with an SCX10 as the base and a bunch of talent and ingenuity.
Pavmentsurfer is offline   Reply With Quote
Old 11-06-2015, 07:53 PM   #10
Thank you for your inspiring comments! Well for once I think I got lucky. I took a couple measurements, and a guess or two as I was really trying to get my "tuck" - the rear tire/wheel combo looked a little wide. So went to Crawler Innovations for a couple of 6 Bolts, 1.5" wide and Vanquish SLW hubs - 325's and a spare set of Trenchers. Think I got exactly what I wanted. Problem is that the 1.5's are to wide for the front, will check out a set of 1" inchers. Got the cage almost complete, waiting for a Exo radiator / fan set before I clean up all the welds. Now back to sanding and another coat of primer. And yes, it had cantilever rear shock set up, but modified the rear for this build.
Old 11-06-2015, 08:22 PM   #11
Location: In West Monroe,LA...yes,where Duck Dynasty is filmed
Who makes the fuel cell?Is it scratch from styrene or store bought?Love the extended body panels.Looks spot on
krazykrawler is offline   Reply With Quote
Old 11-06-2015, 10:11 PM   #12
It's actually the top off a spare Vaterra Blazer radio box I had sitting around. Thanks for the comments too!
Old 11-06-2015, 10:27 PM   #13
Just curious, why not use a more scale tire? Everything about this build is very purposeful so I'm sure you have a reason. It just seems like a typical 1.9 tire might fit better in the wheel wells. Those trenchers are really wide.
Old 11-07-2015, 11:11 AM   #14
Good question.....oddly enough, and it maybe the visual size of the Proline/Trencher combo, my 1.9 Rok Lox are 1/16" wider then the Trencher combo. They are the exact same width as a set of 1.9 Swampers also. I tried 1.55's but the overall height of this combo seems to fit best from a "realisum" perspective, even though the wheel diameter is a bit out of scale. Of course this is my opinion, but I kinda dig it like this.
Old 11-07-2015, 01:30 PM   #15
Quick update, got the cage done, time for clean up and paint time. After the paint shop was done it went to some lite detail assembly. Have to decide if I am mounting 1 or 2 spare tires.
Old 11-07-2015, 01:33 PM   #16
Just got the body back from the paint shop. Little bit of curing time required before I can go any further.
Old 11-07-2015, 05:49 PM   #17
Heading out of town for a few days, just had to see what it looked like sitting on the chassis.
Old 11-08-2015, 06:22 AM   #18
very nice build. Following it for sure
benster is offline   Reply With Quote
Old 11-08-2015, 07:21 PM   #19
You got some serious skills SON!! Great build,keep at it you inspire so many of us
trig n tahoe is offline   Reply With Quote
Old 11-12-2015, 08:19 PM   #20
WOw...Thanks for the kind words!
Still trying to follow a little my inspiration photo. Also never been a fan of decals, but felt compelled to add a few here, just to give the body a bit of a vintage race look. Tackled a few details, grill, lighting and such. Still a ton to do. Added a few Dzus fasteners, albeit also decal based, but really wanted that removable panel look.
SCX10 IFS - Chevy (Clod Based) Prerunner - Similar Threads
IFS Silverado Prerunner... KillerBlackbird 1.9 Scale Rigs 88 02-06-2016 06:45 PM
IFS long travel prerunner? KillerBlackbird General Scale Talk 7 12-04-2013 05:43 PM
