11-07-2015, 02:36 AM | #1 |
Newbie Join Date: Aug 2014 Location: NTHQLD
| Little Falken G6
So thought I might share this build that I've been doing for my daughter. Its based around a Dead Bolt chassis that i picked up of the bay. I've tried to keep it as simple as possible only moding what I felt was realy necesssary. I'll up date as things are changed/repaired. The specs: Hobbywing ESC 1060 Johnson 27t silver can 9t pinion 32p Mirrored gear box Epoxy'd diff lockers Hobbyking 15kg servo Home made links Home made lighting looms SSD rims Mad Beast tyres Chassis Links Mirrored gear box Battery and radio box swaped Basic layout of mechanics and innerfenders and gaurds Rims and tyres Last edited by Team Rawlings; 11-07-2015 at 02:44 AM. |
11-07-2015, 02:55 AM | #2 |
| Re: Little Falken G6
After having its first trail run/shakedown it was time to fit some lights. I've kept them very basic. To reduce the wireing to the spotlights over the windscreen I used a peice of circuit board to creat a buz bar and soldered the leds directly into this with a single lead feeding current. I have a resistor soldered in the lead to control voltage but may need to change it to a lower risitance as the lights are a little dull. Cheers more soon S |
Little Falken G6 - Similar Threads | ||||
New to me g6 falken on the way! | NickGood | Axial SCX-10 | 2 | 06-04-2015 10:47 AM |
Falken G6 | CKRC Hobbies | CKRC Hobbies | 0 | 07-30-2014 11:27 PM |
SCX G6 Falken | odogfish | Axial SCX-10 | 7 | 07-27-2014 10:56 PM |
