11-19-2015, 08:09 PM | #1 |
Pebble Pounder Join Date: Jun 2006 Location: newark
| trailing arms
I was thinking of trying a set on my wroncho . So who has them ? how well do they work for you application ? Also any pics would be appreciated .
11-19-2015, 08:35 PM | #2 |
Rock Crawler Join Date: Nov 2014 Location: Grimcity, On
| Re: trailing arms
I did ta on my scx, with scx axles though. Trailing arm, slightly custom build I think you could possibly use the new rr10 skid plate, its set up for the yeti rear. |
11-19-2015, 09:04 PM | #3 |
Rock Crawler Join Date: Mar 2014 Location: Union City, CA
| Re: trailing arms
I made some for my deadbolt. Was about to throw out some old windshield wiper blades and decided the dremel would touch them first. Granted, they are not likely the best construction, but they are steel, were fun to cut up and fit to the truck. I don't see much performance gain, or loss, but it's different! |
01-17-2016, 08:40 PM | #4 |
Newbie Join Date: Sep 2015 Location: Redding
| Re: trailing arms
You would need to move your lower shock mount to the trailing arms to notice a difference. The whole point of trailing arms is to get those shocks mounted farther forward, onto the arms themselves, which increases the leverage on the shocks and increases travel, along with smoothing things out a bit and lowering the CG. All you did was replace you lower links with new lower links that LOOK like trailing arms. After that you'll have to move the UPPER shock mount location forward, which will also increase leverage and probably travel.
trailing arms - Similar Threads | ||||
VP Trailing arms | busa1320 | Axial Wraith | 9 | 06-16-2015 04:40 PM |
Trailing arms | hotrodsoup | Axial Yeti | 4 | 10-28-2014 10:03 AM |
trailing arms? | haynesn12 | Axial Wraith | 5 | 01-03-2014 11:26 AM |
Trailing arms | chip cross | General Scale Talk | 3 | 10-01-2011 07:09 AM |
