12-21-2015, 03:29 PM | #1 |
Pebble Pounder Join Date: Dec 2015 Location: Portugal
| My Power Wagon
Hi guys, Been surfing trough the forum for quite some time, figured it was more than time to present my first scale truck. Started off as a stock Power Wagon Trimmed the front lexan bumper and fitted a raised steel bumper Pittbull Rockbeasts on Axial beadlock wheels Homemade links Made a template and then fabbed up a raised bumper mount/recessed inverted winch plate / transversely mounted battery tray / electronics box reposition Proline shocks Led light bar made of Aluminium square pipe Axial high clearance knuckles chub Universal's and lockers (Have some binding wobble on one of the Universal's have to sort out somehow) At my 2nd comp Hope you enjoy the pics of my rig. Comments and suggestions are welcome Thanks Sent from my SM-G900F using Tapatalk |
12-22-2015, 06:02 PM | #2 |
Rock Crawler Join Date: Mar 2006 Location: Dogpatch
| Re: My Power Wagon
Cool.Those rocks look knarly!
12-22-2015, 08:05 PM | #3 |
Rock Stacker Join Date: Feb 2013 Location: montreal
| Re: My Power Wagon |
12-22-2015, 09:14 PM | #4 |
| Re: My Power Wagon
Looks like you are off to a good start. My suggestion is drive drive drive. Find one thing you would like it to do better and address the problem. These problems will be different from one driver to another so you are really the only one who can answer that.
12-22-2015, 10:10 PM | #5 |
Rock Stacker Join Date: Sep 2005 Location: prescott
| Re: My Power Wagon
Those Rocks Look Crazy.Nice Rig. |
12-23-2015, 12:42 PM | #6 | |
| Re: My Power Wagon Quote: The links are easy to make: 3mm stainless threaded rod Aluminium pipe to sleave them and add more strength Traxxas rod ends Metal saw & vice (much faster than dremel) And the old saying: measure twice cut once For the lowers I got a cheap pipe bender and bent them with the rod and pipe together. Add 6~7mm to the original length to compensate for the bend and 6mm of thread poking out from each side. Took also the oportunity and clocked the axles ( longer upper links) for more clearance. When I installed the Axial aluminium chub got my caster angle back in line. Like your front bumper also, looks like it belongs there Sent from my SM-G900F using Tapatalk | |
12-23-2015, 01:50 PM | #7 | |
This is my first hobby grade rc and I was quite surprised with the rigs performance out of the box. One thing I knew for sure even before buying it, I love to thinker with stuff so for sure I would find things to change/modify on the truck. Sent from my SM-G900F using Tapatalk | |
12-23-2015, 04:07 PM | #8 |
| Re: My Power Wagon
Small update, the skid arms where snagging sometimes. Added two pieces of styrene under them. Seem to work well Sent from my SM-G900F using Tapatalk |
01-01-2016, 04:03 AM | #9 |
| Re: My Power Wagon
New upgrades on the way: 35T motor NobBrainer BEC High torque servo New chassis & new Links Will keep thread update as soon as parts arrive and I have the time to install them Sent from my SM-G900F using Tapatalk |
01-01-2016, 06:10 PM | #10 |
| Re: My Power Wagon
great! thanks for the info. looks like im off to home depot soon for supplies the front bumper is from scalerfab aswell.. they are super tough. cant wait to see your update! |
02-05-2016, 04:09 PM | #11 |
| Re: My Power Wagon
New update: Homebrew Carbon Fibre chassis rails installed. Reorganised the layout to try and lower the CoG Changed to 2x small 800mah 3S batteries running in paralel Have to say the Homebrew carbon chassis is top notch! Great articulation clearance and shock mounting options. Sent from my SM-G900F using Tapatalk Last edited by OvrKll; 02-05-2016 at 04:14 PM. |
02-05-2016, 07:55 PM | #12 | |
"GOD SPEED" Join Date: Oct 2014 Location: Wouldn't you like to know
"GOD SPEED" | |
02-09-2016, 07:22 AM | #13 |
| Re: My Power Wagon
New update : got tired of the stock bed hanging up all the time like an ancor. Lifting the truck is against low CoG so I'm making a new bed - comp style. Tried with aluminum pipes but figured it would just add unwanted weight soooo Plastic tubes it is 8mm tube with 3mm styrene bed. Bent with a lighter Will add top tubes all the way back, but first will paint the bed with bedliner effect. Not perfect, but with some sanding, filling and a coat of black should look decent Sent from my SM-G900F using Tapatalk |
02-12-2016, 12:19 PM | #14 |
| Re: My Power Wagon
Small update on the truck bed Will add a rear radiator from my Yeti's parts bin, two more pipes and off to paint Sent from my SM-G900F using Tapatalk |
02-12-2016, 06:36 PM | #15 |
| Re: My Power Wagon
Nice work with the tubing, how are you bonding it together to get it to hold when rolled? "GOD SPEED" |
02-13-2016, 10:50 AM | #16 |
| Re: My Power Wagon
Thanks nerby. I'm using cyano glue, a few drops at a time to bond and build up so I can sand it smoth before painting. The pipe angles I wrap some sand paper around a pencil and snd down to match the intersection. Dremel w/ sand roll works much faster but I'm doing this in the living room when my son goes to bed, so power tools are not an option. Next step some girders on some of the corners made with 3mm styrene to reinforce and add some scale detail Sent from my SM-G900F using Tapatalk |
02-21-2016, 06:32 AM | #17 | |
"GOD SPEED" | |
02-21-2016, 08:06 AM | #18 |
| Re: My Power Wagon
Finished yesterday night, will post some pics shortly Sent from my SM-G900F using Tapatalk |
02-21-2016, 08:29 AM | #19 |
RCC Addict Join Date: Feb 2008 Location: your back yard
| Re: My Power Wagon
I'm liking that plastic cage. I've always wondered if it would hold up to some rolls, only time will tell. ;)
02-21-2016, 11:04 AM | #20 |
| Re: My Power Wagon
Here she be! Sanded everything down as much as possible to eliminate imperfections from glue etc. One coat of plastic primer and two coats of lexan black paint Added the radiator from my Yeti's spare parts bag painted in silver with some black drybrush effect for scale looks Made a support bracket I made from styrene And a rotating support so I can swivel open the body from Yeti parts and styrene bracket Now have to wait for my new servo to arrive (stock one died at the end of that last crawling session) I gave the tray some good squeezes before painting and it felt solid. But the proof of course will be when I flip the rig a few times. For now I'm pretty happy with the results, it's not perfect but I'm not making a shelf queen so good enough for me. Now debating if I should paint the body black, wrap it or just leave it alone. What do you guys think? Sent from my SM-G900F using Tapatalk Last edited by OvrKll; 02-21-2016 at 11:09 AM. |
My Power Wagon - Similar Threads | ||||
Project B.A. Power Wagon (Bad A** Power Wagon) | freetimecrawler | 1.9 Scale Rigs | 1 | 12-30-2018 07:19 AM |
My New Power Wagon | 95BlackZ26 | Axial SCX-10 | 10 | 02-22-2016 12:02 AM |
1964 Dodge Power Wagon Town Wagon | bodean | 1.9 Scale Rigs | 32 | 05-29-2015 11:02 AM |
My Power Wagon!!!! | PCHILNSF | Axial SCX-10 | 12 | 02-01-2015 03:25 PM |
60 in a 73 power wagon | losikid | Chit Chat | 13 | 10-10-2011 08:27 PM |
