12-23-2015, 04:03 PM | #1 |
Pebble Pounder Join Date: Dec 2015 Location: Portugal
| New servo advice
Hi guys, So my stock Tactic TSX45 is starting to go. Found a good deal on a Savox SC1256TG. I'm running the AE-5 ESC w/ 35T & 2s (thinking on going 3s shortly) Question: will a Nova 5626 Glitch Buster be enough to ensure proper operation or will I need a BEC? Really need some advice Sent from my SM-G900F using Tapatalk |
12-23-2015, 04:54 PM | #2 |
RCC Addict Join Date: Oct 2011 Location: British Columbia
| Re: New servo advice
Without question...an external BEC
12-23-2015, 05:22 PM | #3 |
Rock Stacker Join Date: Dec 2015 Location: East TN
BEC...once you run one you will never go back
12-23-2015, 05:24 PM | #4 |
Newbie Join Date: Nov 2015 Location: Fairbanks
Hmmm. I have a new SCX10 Jeep Wrangler C/R with stock motor/esc. It is new. I changed the servo to the same one [Savox SC1256TG] while doing the RC4WD chassis mount for servo work. The servo humms, but works. I use 2S batteries. I wouldn't think an external BEC would be needed for this servo with that load, but am I wrong? Mike |
12-24-2015, 04:40 AM | #5 |
Thanks for the comments. Considering FVIcySwan has the same setup as I do I'm hoping to get away with not needing a BEC for now. Will see also if with a 3S will work. For sure I will get a BEC later on so I can run lights and winch off one battery but would rather put this off for further down the line. It's a slippery slope for the wallet when we start making modifications. Thanks again Sent from my SM-G900F using Tapatalk |
12-24-2015, 06:11 AM | #6 | ||
| Re: New servo advice Quote:
Something to consider... I have killed 2 differant escs from not running a external bec. Both were stock powered servos that killed them. Traxxas 2675 and my stock losi mrc | ||
12-24-2015, 06:16 AM | #7 | |
Have to keep a good eye on mine when I install the Savox servo. Anyone have experience with glitch busters (capacitor)? Would that help? Sorry I'm a noob at rc electronics. Sent from my SM-G900F using Tapatalk | |
12-24-2015, 07:33 AM | #8 | ||
Newbie Join Date: Dec 2015 Location: Oconee County, SC
Savox servos are typically very power hungry. At the very minimum a glitch buster is highly suggested. The optimal would be an external BEC with a 6v setting. Stock Axial receivers are rated for no more than 6v. I have also seen Savox's that required a 6v input and the use of a glitch buster to get then to function without brown outs or glitching. If your servo is rated for more than 6v you can get an external BEC rated for more voltage and wire it directly to the servo. Leaving the receiver running off the internal BEC. Quote:
12-24-2015, 08:29 AM | #9 | |
Servo runs at 6v, for adding a winch and lights off a 3S 40C lipo, would you say a 10A Castle BEC would suffice? Thanks Sent from my SM-G900F using Tapatalk | |
12-24-2015, 08:33 AM | #10 |
Quarry Creeper Join Date: Jun 2015 Location: Athol, Massachusetts
YES |
12-24-2015, 08:42 AM | #11 | |
HOBBYWING North America — UBEC-3A (2-6S Lipo Input) I would wire the winch directly off the battery if you're planning on this one RC4WD 1/10 Mini Warn 9.5cti Winch With this controller RC4WD Warn 1/10 Wireless Remote/Receiver Winch Controller Set Last edited by Redbone; 12-24-2015 at 08:45 AM. | |
12-24-2015, 09:42 AM | #12 | |
No excuses now Will be using a 3racing winch but I guess the setup should not differ much. Thanks for taking the time to explain these things, much appreciated! Sent from my SM-G900F using Tapatalk | |
12-24-2015, 10:58 AM | #13 |
A castle 10a would be the one I recommend. Its adjustable and reliable, and only $25. Remember you often get what you pay for. (Especially in electronics).
12-24-2015, 11:09 AM | #14 |
Have run that HW UBEC in several models for years with absolutely no problems what so ever. Just cause it has a lower price tag doesn't mean it's garbage! Many times the units with the big name and the High $ you get exactly what you pay for, the marketing and the name, but not necessarily a better product.
12-31-2015, 12:05 AM | #15 |
Newbie Join Date: Mar 2015 Location: LA
if the power hungary of sc-1256tg is a pain for you. you could try the XQ-S4120D. it's a high performance HV servo from XQ POWER, can handle 8.5 maximum(ok with full-charged 2S lipo) |
12-31-2015, 09:29 AM | #16 |
NobBrainer adjustable BEC 2X CH on it's way. Will probably try to convert the TSX45 into a servo winch and replace the plastic gear w/ metal one. If I pull it off I save on the 3racing winch cost Sent from my SM-G900F using Tapatalk |
New servo advice - Similar Threads | ||||
Replacement Servo Advice | My(2)Cents | Axial Wraith | 7 | 06-29-2013 03:29 PM |
Servo Advice - New XR10 owner | Nepptune | Axial XR10 | 11 | 01-15-2013 01:13 PM |
Need advice for a good servo... | munsonator08 | Newbie General | 4 | 07-20-2011 05:50 PM |
what servo to use? advice please! | j.gorilla | Newbie General | 15 | 05-11-2011 01:42 PM |
Servo advice | SMFtwstdHICK | Electronics | 2 | 08-01-2008 06:49 PM |
