08-08-2016, 11:32 AM | #1 |
Newbie Join Date: Jun 2015 Location: San Diego
| SCX10 12" G6 - MIP Drive Shafts (Transmission Cover)
Hi, After advice if possible, I have the MIP drive shafts specific to the 12" WB G6. One of the drive hubs is longer to assist with clearing the transmission. Unfortunately it looks as if it is still too bulky to allow for the transmission cover to remain. I looked at the holmes hobbies extended transmission outdrives but was advised it would not allow enough travel for the MIP drive shaft. Do you generally run without transmission cover? (a little risky I guess, would need to use dry lube). Do you cut out the corner of the cover? (less risky but dirt could still get in) Have an alternative solution? These are the MIP's I have; MIP C2 X-Duty CVD™ Spline Drive Kit, Axial Jeep Wrangler (#AX90036), #15220 Cheers Richard |
08-08-2016, 11:58 AM | #2 |
| Re: SCX10 12" G6 - MIP Drive Shafts (Transmission Cover)
I run without spur covers and have for a while. Zero issues and no lube needed. It would just attract dirt.
08-09-2016, 01:10 PM | #3 |
I wanna be Dave Join Date: Nov 2014 Location: West Texas
I use the dremmel tool to get the needed clearance. I only use covers on my rig with a winch or jrs rig. I got the winch line caught up in the spur at a comp not doing that again. 149 r/c worx team driver Last edited by snapon boy; 08-09-2016 at 04:56 PM. |
08-09-2016, 04:54 PM | #4 |
| Re: SCX10 12" G6 - MIP Drive Shafts (Transmission Cover) |
08-09-2016, 04:56 PM | #5 |
| Re: SCX10 12" G6 - MIP Drive Shafts (Transmission Cover) As a crawler I guess it wouldnt naturally reach speeds where lubricant would be vital or necessary. I'm running hardened 32pitch pinion and spur though so should be fine with fine dust.
08-09-2016, 05:06 PM | #6 |
I joined the Band! Join Date: Feb 2015 Location: On a rock
My 50mph 1/8 scale never saw so much as a drop of lube on her spur gear.. Thats asking for trouble.
08-09-2016, 05:16 PM | #7 |
| Re: SCX10 12" G6 - MIP Drive Shafts (Transmission Cover) Here is a picture of a few of my rigs. The shafy has no cover, my homebrew scx10 has a trimmed cover because I don't want the winch line in it again, my son's homebrew scx10 has a cover because he is 5, my 6x6 has a cover because I haven't smashed the ble pro yet and cleaned up the rest of the wiring. My winch is able to be plug play completely removable with 2 screws and 1 mini t plug and a futaba connection. If I go to a comp/event and don't need a winch I pull it to save weight. With a winch and body my scx10 weight is 5 lb 10oz without the winch it almost 5lbs which makes for a super perform. I ran the last few years without a transmission cover to save weight, you really don't need it /unless you use 32p spur gear and pinion once and a while a pebble will get stuck in between them. I hope this helps you if not pm me and I'll try to answer your questions. Fish 149 r/c worx team driver |
08-09-2016, 07:34 PM | #8 | |
| Re: SCX10 12" G6 - MIP Drive Shafts (Transmission Cover) Quote:
08-09-2016, 09:36 PM | #9 |
I've never had that happen to me rock in spur gear/pinnion but seen it happen to others once. 149 r/c worx team driver |
SCX10 12" G6 - MIP Drive Shafts (Transmission Cover) - Similar Threads | ||||
MIP Drive Shafts for SCX10 | jray | Newbie General | 9 | 08-15-2011 04:30 PM |
