10-17-2016, 02:58 PM | #1 |
Quarry Creeper Join Date: Dec 2015 Location: ossipee
| servo winch
Are there any aftermarket parts that make mounting a servo winch easy on a scx10
10-17-2016, 09:59 PM | #2 |
Rock Crawler Join Date: May 2013 Location: Uniontown
| Re: servo winch
Willing to go to an outside rail mount front bumper? GCM dual servo mount kit. You can also go CMS eventually. Or they make a single servo mount that lets you retain factory bumper with a little modification. Sent from my XT1585 using Tapatalk |
10-18-2016, 12:12 PM | #3 |
| Re: servo winch
Im already running vanquish cms kit just looking for a easy way or aftermarket bracket for mounting a servo winch .
10-19-2016, 06:49 AM | #4 |
| Re: servo winch
Hmm, ok, the Vanquish one mounts along frame rail, so that precludes a cross frame mount. You might be able to make something out of two servo mounts and a drill to mirror the Vanquish steering servo mount. Sent from my XT1585 using Tapatalk |
10-19-2016, 07:07 AM | #5 |
| Re: servo winch
Or maybe it doesn't. Looking closer, is there still room for the front bumper mount? If so, then the Vanquish bumper/servo mount may still fit. http://www.vanquishproducts.com/axia...lear-anodized/ Sent from my XT1585 using Tapatalk |
10-19-2016, 11:48 AM | #6 |
| Re: servo winch
Might work ill check it out i can't believe nobody makes a bracket for a servo winch that works with a chassis mounted servo
10-19-2016, 09:41 PM | #7 |
| Re: servo winch
Most of the ones that do mount both servos Sent from my XT1585 using Tapatalk |
10-19-2016, 10:38 PM | #8 |
Quarry Creeper Join Date: Aug 2014 Location: Glendive, Montana
| Re: servo winch
On my Deadbolt, i had a Locked Up Rc CMS kit, than modified a Vanquish mount to use on the other side for my servo winch. With the body on, barely seen it. |
10-19-2016, 11:24 PM | #9 |
RCC Addict Join Date: Dec 2012 Location: Crookston
| Re: servo winch
Can also check out the one from BP Custom Chassis... http://bpcustomchassis.com/webstore....egory=11952206 |
10-21-2016, 06:34 AM | #10 |
| Re: servo winch
Thanks
