10-30-2016, 07:29 PM | #1 |
I wanna be Dave Join Date: Sep 2004
| scx10 steering geomitry
is there a reason that is fixable for the scx10 steering to one side more then the other? i did some research and found people complaining about it with very little info on how to fix it. it has to be something with where the steering link is mounted. the one off the servo. i can fix it with end points but only by taking steering away. |
10-30-2016, 07:45 PM | #2 |
| Re: scx10 steering geomitry
none of my scx10's exhibit that problem...any pics to show it?
10-30-2016, 09:33 PM | #3 | |
| Re: scx10 steering geomitry Quote:
it has to be link length and servo position. something i havent farted around on this truck. what got me thinking its a scx10 geometry problem is i know others that have this issue. | |
10-30-2016, 10:32 PM | #4 |
I am running axial high clearance knuckles on strc chubs with axial cvd's my left and right turns are maxed out...the steering arms turn until they hit the chubs...
11-15-2016, 12:29 AM | #5 | |
Pebble Pounder Join Date: Mar 2016 Location: Mountains
works better but the plastic link ends are week | |
11-15-2016, 01:45 AM | #6 | |
Quarry Creeper Join Date: Oct 2012 Location: Malang, Indonesia
1. properly re-align the servo horn to center as possible? 2. set the steering trim to the left of the right to adjust the problem? oyaa what did you mean by "taking the steering away"? | |
11-15-2016, 08:29 AM | #7 |
Quarry Creeper Join Date: Jun 2014 Location: Grand Haven, MI
The ackerman angle is backward on the scx10. Instead of the inner tire turning farther than the outer, it's the other way around. It creates TONS of understeer. The only thing that will help is to add a little bit of toe out using the steering link. Once you do that, the ackerman is at least equal distance. It helps a ton. Last edited by 1967Typhoon; 11-15-2016 at 08:31 AM. |
11-15-2016, 09:15 AM | #8 | |
ok, now i get it, the op is talking about one tire having a sharper turning angle than the other...mine do indeed have that, but they turn so sharp anyway that i dont care lol | |
11-15-2016, 10:27 AM | #9 | |
11-15-2016, 12:02 PM | #10 |
You need to adjust the length of the link that connects the two steering knuckles. If it isn't an adjustable link, you should think about upgrading it to a metal link with adjustable ball ends. I just reread your post though, and it sounds like you need to center your servo properly, and make sure the wheels are as straight as possible when you put the servo horn on. |
11-18-2016, 10:43 PM | #11 | |
the servo is centered properly. since i made this post i have found out part of the problem. the servo plate was not tight and the movement that it created wasnt noticeable till i really tore into it. the root of the problem i believe and i could be wrong is the servo horn is not centered in the middle of the axle.if i adjust the servo horn so it sits in the middle of the pumpkin at neutral that could fix the problem if i was able to adjust my main steering link but i can as it is the fixed hot racing one. | |
scx10 steering geomitry - Similar Threads | ||||
Need more steering for scx10 | sixhundred71 | Newbie General | 11 | 07-04-2011 01:09 PM |
scx10 steering | SCcrawler | Electronics | 2 | 03-27-2011 08:24 PM |
scx10 steering | 97koukiman | Axial SCX-10 | 0 | 04-17-2010 10:07 AM |
link geomitry | levi steele | Tamiya TLT Crawlers | 1 | 12-06-2007 11:58 PM |
