11-19-2016, 06:29 PM | #1 |
Newbie Join Date: Nov 2016 Location: US
| Scx10 with AE-5 esc running 3s lipo keeps shutting off
I have a scx10 ram power wagon with the stock 27t motor and AE-5 ESC I have a 3s I ran on it today for the first time I have been running a 2s for the last two months and no problem but today I was at a scale course with a 3s and I got in a position when I needed some torque and the esc shut off and I lost driving but had steering I messed around for a few seconds and the esc beeped like normal and it came back but it kept shutting off what do I do please help!!! Sent from my SM-G920R4 using Tapatalk |
11-19-2016, 07:41 PM | #2 |
I wanna be Dave Join Date: Nov 2014 Location: West Texas
| Re: Scx10 with AE-5 esc running 3s lipo keeps shutting off
Sounds like low voltage cut off or you need a bec to run 3s. 149 r/c worx's Team Driver |
11-19-2016, 07:43 PM | #3 |
Rock Stacker Join Date: Mar 2016 Location: Los Angeles
Castle BEC should do the job. The receiver might not be able to handle it properly without glitching. I have a waterproof Castle 10amp BEC that I don't need anymore. PM me if you would like to buy it. Sent from my iPad using Tapatalk |
11-19-2016, 08:02 PM | #4 | |
| Re: Scx10 with AE-5 esc running 3s lipo keeps shutting off Quote:
Sent from my SM-G920R4 using Tapatalk | |
11-19-2016, 08:16 PM | #5 |
Not at all. It will unload the esc and give the Servo load to the Servo and battery. 149 r/c worx's Team Driver |
11-19-2016, 08:52 PM | #6 |
Rock Crawler Join Date: Feb 2010 Location: Central/SE Ohio
Your esc is going into Thermal protection. An ae-5 with 3s is going to Overheat commonly with anything under a 35t especially if not geared down alot too. I messed around with ae-5's and before it was all said and done, I got tired of having to let them cool after they thermally shutdown, then if any situation came up where there was a heavy bind on the drivetrain for more than a few seconds often the ae-5 esc would let out that magic ohm smoke. I smoked a total of 5 of them over the last year. My advice if you want them to last is to gear down as much as possible and go up in turns on the motor. Bypassing the esc for the servo will help too but in all 5 of my cases the esc's still let go on 3s despite a bec bypassing the esc. A fan would help alot too, as well as making sure you've got adequate airflow to the circuit board cooling fins.
11-20-2016, 05:27 AM | #7 | |
11-20-2016, 05:34 AM | #8 |
Are you wanting to stay brushed or go brushless later on? 149 r/c worx's Team Driver |
11-20-2016, 05:35 AM | #9 |
| Re: Scx10 with AE-5 esc running 3s lipo keeps shutting off |
11-20-2016, 05:38 AM | #10 |
11-20-2016, 05:44 AM | #11 |
Holmes Hobbies ble pro or, castle momba. These are what I would look into. However I would try your ae5 with the bec 1st and see how it dose. You will want the bec regardless. 149 r/c worx's Team Driver |
11-20-2016, 05:45 AM | #12 | |
11-20-2016, 05:52 AM | #13 |
You can conformal coat your bec to help make it water resistant. 149 r/c worx's Team Driver |
11-20-2016, 05:53 AM | #14 |
11-20-2016, 05:54 AM | #15 |
All the castle stuff I've gotten comes waterproof except the bec however there about to release one that is. The Holmes Hobbies stuff can be bought waterproof as well 149 r/c worx's Team Driver |
11-20-2016, 08:42 AM | #16 |
Hey Bobcat, like Snapon says, Holmes Hobbies stuff is the real deal. I have never been dissapointed by anything from HH. He makes the BEST product available today far as I can tell.
Scx10 with AE-5 esc running 3s lipo keeps shutting off - Similar Threads | ||||
Do I still need a BEC if running Dual FXR ESC one Servo not HV w/ 3S Lipo | Strychnine | Electronics | 6 | 05-09-2014 09:29 PM |
what is the fastest, most durable brushed motor, running 3S LiPo, on AE-2 esc? | ussprinceton2004 | Electronics | 3 | 02-12-2012 09:18 PM |
Esc,motor and lipo running hot. | dr_rookie7 | Venom Creeper | 10 | 09-23-2009 09:46 AM |
