11-29-2016, 10:16 AM | #1 |
RCC Addict Join Date: May 2015 Location: Price Twp.
| SCX10 skid no mounting holes
I'm looking for a scx10 skid that has no mounting holes predrilled. Does anyone have any suggestions for a source of supply?
11-29-2016, 03:36 PM | #2 |
I wanna be Dave Join Date: Aug 2006 Location: under a rock and a hard place
| Re: SCX10 skid no mounting holes
Try toyzuki, I am sure he wouldn't mind not drilling holes in his skids
11-29-2016, 03:36 PM | #3 |
Performance 3d solutions on FB might be able to print without holes also.
11-29-2016, 05:02 PM | #4 |
I wanna be Dave Join Date: Nov 2014 Location: West Texas
Hit up nerby149 he's a vendor who makes custom skids here on rc crawler. 149 r/c worx's Team Driver Last edited by snapon boy; 11-29-2016 at 08:51 PM. |
11-30-2016, 08:54 AM | #5 |
thanks Ill look into them |
11-30-2016, 03:46 PM | #6 |
Rock Stacker Join Date: Sep 2016 Location: United States
Just out of curiosity, what did you plan on using it for?
12-02-2016, 07:29 AM | #7 |
| Re: SCX10 skid no mounting holes I have a scx10 aftermarket frame that currently has an axial skid in it. I am using a forward mounted tranny and a skid mounted transfer case. The stock skid doesn't have enough meat on it for a solid mounting. I was thinking a solid skid where I can transfer the hole pattern then drill and recess new mounting holes.
12-02-2016, 08:18 AM | #8 | ||
I'll assume you are referencing the center skid ? Would be helpful to tell us what frame (chassis) is being utilized. Quote:
thickness - width ? ...pictures detailing ? Quote:
Thickness or width of say Steel plate - Delrin plate ? ^ Pictures make for a better understanding. There are production alloy skids... Delrin skids... and even custom homebrew skids... available. anywhere from 1/4" - 3/8" thick. But with your limited information/lack of detail... Some of us are unable to ascertain exactly what your wants/needs are. | ||
12-02-2016, 08:36 AM | #9 | |
| Re: SCX10 skid no mounting holes Quote:
The GCM t-case lines up with the 2 outer holes in most skidplates so only 2 holes have to be drilled. I'm using the TSS skid for my project but any of the flat delrin skids work well for this purpose, the extra holes end up on the blank side of the skid. There should be plenty of space to drill holes for a RC4WD t-case as well. | |
12-02-2016, 09:29 AM | #10 |
Not enough meat means that many are recessed to save weight I am assuming. I just grabbed a generic skid, but you can see the recesses in it. I am hoping to find something like this without any pre drilled holes. I currently have this t-case installed. Currently I am using one stock hole, then 3 others with washer shims, Im looking to get a solid mounting surface. Last edited by Ditchrat; 12-02-2016 at 09:34 AM. |
12-02-2016, 02:43 PM | #11 |
Quarry Creeper Join Date: Aug 2014 Location: Orange County
I actually had a skid 3d printed to work with that transfer case. Maybe I can help you out. Pm me Sent from my SM-G920T using Tapatalk |
12-02-2016, 03:03 PM | #12 | |
Not sure who makes one that sells one undrilled... But if it were made of Delrin or steel that would be best. Aluminum, tho' maybe durable, doesn't slide on/off the rocks very well. Maybe if ya contact these folk... they can make one without holes drilled ? http://thescaleshop.webs.com/chassis.htm Last edited by TacoCrawler; 12-02-2016 at 03:12 PM. | |
SCX10 skid no mounting holes - Similar Threads | ||||
mounting holes: yeti VS scx10 trans | navyeoseabee | General Crawlers | 1 | 04-07-2015 11:48 PM |
Body mounting, no holes? | Deerhurst | Axial SCX-10 | 2 | 12-25-2012 08:13 AM |
high lift and tlt axel same mounting holes? | brendan h | General Scale Talk | 3 | 01-02-2009 09:00 PM |
