11-30-2016, 11:27 AM | #1 |
Pebble Pounder Join Date: Feb 2015 Location: in my house
| Raised Chassis + CMS Geometry
Hello, I am thinking of getting a raised chassis such as the TSS SCXHR one, but I have a CMS and I think that raising the chassis would change the Panhard link and tie rod geometry, because the chassis/servo mounting points would be higher up than they would have been before. Could someone please clarify whether or not a raised chassis would affect my CMS geometry? Thank you! http://www.rccrawler.com/forum/axial...upgrade-4.html |
11-30-2016, 11:40 AM | #2 |
| Re: Raised Chassis + CMS Geometry
It does change the geometry but nothing too serious. I have the TSS chassis and I used the same Vanquish CMS links as on the regular chassis but had to unscrew the rod ends a few turns on the panhard to lengthen it a bit. Also swapped one of the drag link rod ends to a Jato end for some extra length. Once the proper lengths of the links are nailed down, the additional clearance will let the suspension cycle with unrestricted movement. I could never get full travel on the passenger side with the stock chassis. |
11-30-2016, 11:42 AM | #3 | |
| Re: Raised Chassis + CMS Geometry Quote:
11-30-2016, 12:12 PM | #4 |
you will LOVE the SCXHR!
Raised Chassis + CMS Geometry - Similar Threads | ||||
Raised slid plate | Espo | Vaterra Ascender | 4 | 09-14-2016 06:57 PM |
Trailfinder linked geometry vs SCX10 geometry | arnesto | RC4WD Trail Finder 2 | 0 | 05-04-2013 10:17 PM |
Raised Upper Links | losikid | Team Losi Comp Crawler | 0 | 03-03-2011 05:57 PM |
