Thread: Best parts for 100$?
Old 12-26-2016, 07:39 AM   #1
Default Best parts for 100$?
I recently got a super good deal on eBay for an scx10 ii with tons of upgrades. The truck was fully converted to a three link with hand brothers pan hard kit, new ssd axles with hd gears and tons more. I got a 100$ for Christmas, and need to get a new Lipo, but with the remaining 60$ or so, what are some good parts
Fuzzypelican99 is offline   Reply With Quote
Old 12-26-2016, 07:46 AM   #2
Default Re: Best parts for 100$?
Try Hobby King for Lipos great prices and pretty good batteries as well.
not sure on the parts not sure what is already upgraded and what is not.
welcome to the forum by the way,
sharkattack99 is offline   Reply With Quote
Old 12-26-2016, 07:48 AM   #3
The truck has all new links, shock mounts, aluminum receiver box, chassis braces, hubs and lockouts, new driveshafts, And a skid plate
Old 12-26-2016, 07:49 AM   #4
I was trying to find bumpers, cause the rear broke in shipping and the front bottoms out on rocks a lot. Thanks for the feed back!
Old 12-26-2016, 07:55 AM   #5
I believe SSD has some bumpers that offer more clearence for the front may check them out.
sounds like its pretty well upgraded with most of the parts ppl usually upgrade. so it maybe just upgrades you want and not necessarily what is needed, which is the fun part lol
Old 12-26-2016, 07:58 AM   #6
Ok thank you, my local shop carries a lot of crawler parts so I'll see what they have.
Old 12-26-2016, 08:15 AM   #7
im sure someone will chime in with maybe a few more suggestions.
what motor and esc is currently in the rig? may save up and get a brushless system from holmes hobbies, if its not brushless already just a thought.
Old 12-26-2016, 08:16 AM   #8
It has an axial ae-5 with a 35 turn motor and a tactic metal gear servo
Old 12-26-2016, 10:40 AM   #9
I am going to guess the servo it has is probably still the Tactic TSX45, if it does, it isn't technically Full Metal Gears. The TSX45 has a plastic gear that is prone to stripping, you can either get a different Servo and or take and go on E-Bay and try and find the metal gear upgrade for it, it's a bit of a pain to find though, but it is typically $9.99 for the part.
I will say the Holmes Hobbies Motor/ESC is a good upgrade route, a bit expensive but good. Either way you go whether brushed or brushless is a great option from Holmes Hobbies. A lot of people are going with a 540 2700kv option from Holmes Hobbies as well as his trailmaster BLE Pro ESC. I personally went with a 2700kv Stubby (didn't have 2700kv in standard) and a Castle Mamba Max Pro that I waterproofed myself.
malickie is offline   Reply With Quote
Old 12-26-2016, 11:05 AM   #10
It sounds like you either got an SCX10 original or someone removed the axles and panhard from an SCX10 II and installed axles, front links and panhard that were designed for the original SCX10.
SSD doesn't make axle housings for the SCX10 II yet, and the SCX10II comes stock with chassis mounted servo and panhard.
Doesn't mean it is a bad rig, just sounds like it isn't a complete SCX10 II.
Sammy J. is offline   Reply With Quote
Old 12-26-2016, 11:12 AM   #11
Budget Truck parts list:
-Servo:
I take all my servos appart & GE SiliconeII the boards & entire backplate, & dielectric grease the output shaft on the front & case seams.
Hobby King 20kg, My old reliable servo I have a few of these & great for the price. - https://hobbyking.com/en_us/hobbykin...16sec-66g.html
PowerHD 20kg, Little gutless but has been working well. - Power HD LW-20MG Digital Servo for RC Cawlers | Value Hobby
-Battery:
Go big or go home, few hours of run-time never hurts.
Love my Zippy packs - https://hobbyking.com/en_us/zippy-fl...-2s1p-30c.html
Turnigy packs too - https://hobbyking.com/en_us/turnigy-...case-pack.html
-Tires:
Bang for the buck, DuraTrax Showdowns - TowerHobbies.com | Duratrax Showdown CR 1.9" Crawler Tire C3 (2)
-Rims:
Extra weight down low, Aluminum & style-ish.
https://www.amazon.com/Scale-RC-Craw...5%3A2470955011
https://www.amazon.com/RC-Car-Crawle...5%3A2470955011
Front Bumper:
Take the stock one & trim the extra plastic around the pegs, & drill an extra hole to move it way back. The wings will need trimming to not rub the tires too.
GLwagon is offline   Reply With Quote
Old 12-26-2016, 11:15 AM   #12
Sorry Sam I should have stated at the start that it isn't. It's an original scx10 with the body, wheels, and electronics of the 2.
Old 12-26-2016, 11:16 AM   #13
Thanks glwagon I have a set of 1.9 axial beadlocks with rockcrushers on them. Definitely gonna look into the batteries.
Old 12-26-2016, 11:19 AM   #14
I also have a 6600mah 60c 2s, but it has a busted balance plug I need to get fixed.
Old 12-26-2016, 06:34 PM   #15
I've been liking these glacier lipos. My buddy the quad/engineer guy gave me 2 3s's to try. They seem to be a decent price online.
sdmf is offline   Reply With Quote
Old 12-29-2016, 03:41 PM   #16
Natedog's Avatar
RC4WD or SSD stamped steel beadlocks with Proline or CI foams.
2200mah lipos, way better crawling ability, carry a couple spares in your pack and change them out. 5000mah and big batteries in SCX10 really kill the crawling ability.
Best parts for 100$? - Similar Threads
Whose quote is give 100 people a chassis and they'll build it 100 diff ways? Rig Rocker Chit Chat 6 10-05-2010 10:40 AM
