12-31-2016, 01:53 PM | #1 |
Rock Stacker Join Date: Mar 2016 Location: Los Angeles
| Super 300s
Does any of you know if the Super 300M 6mm CVD for Axial + Spool Difflocker will work with the wraith c hubs and knuckles? I don't think that is the Hd version. I know the super 300s are like legends nowadays, but one of my friends found a set in his tool box and he sold it to me. Sent from my iPad using Tapatalk |
12-31-2016, 02:39 PM | #2 |
I wanna be Dave Join Date: Aug 2006 Location: under a rock and a hard place
| Re: Super 300s
No, the length of the stub shaft is different with the wraith c's and hubs. They will work with the vanquish 8* c's and hubs for the scx10. Those are the standard scx10 versions, non hd. Last edited by hotwheels000; 12-31-2016 at 02:42 PM. |
12-31-2016, 03:08 PM | #3 | |
| Re: Super 300s Quote:
Do you know if they will work with the axial scx10 F9s? Since they utilize 6x11x4 (am I correct?) bearings. If I can't use wraith knuckles and c hubs, is there a way to maximize my steering to around 45-50 degrees with these on? Sent from my iPad using Tapatalk | |
12-31-2016, 03:11 PM | #4 |
| Re: Super 300s
What I can also do is get some custom F9 tubes from TJ RC so he can make them 6x11x4 compatible if the VP ones don't fit Sent from my iPad using Tapatalk |
12-31-2016, 03:18 PM | #5 |
Rock Crawler Join Date: Sep 2011 Location: truckee
| Re: Super 300s
You need ax/scx10 8° C-hubs and these conversion bushings. Then you can use wraith knuckles. SDS Customs Brass Knuckle Adapters | |
12-31-2016, 03:27 PM | #6 | |
Thank you so much!! But do you know if they fit the VP F9s since they use a bigger bearing? Sent from my iPad using Tapatalk | |
12-31-2016, 07:10 PM | #7 |
| Re: Super 300s
Yeah they'll fit. The bearing is only bigger on the I.D.
12-31-2016, 08:28 PM | #8 |
| Re: Super 300s I think you have got it wrong, after doing some research it appears that only the HD version will work with the bushing+8degree+wraith knuckle. I might be wrong. Are you running this setup(non-hd version with 8 degree vp scx c hubs with wraith knuckles and sds bushings)? Sent from my iPad using Tapatalk |
12-31-2016, 08:34 PM | #9 | |
Super 300s - Similar Threads | ||||
super 300s | lifted_xj | Axial SCX-10 | 3 | 04-24-2011 10:09 PM |
