01-19-2017, 06:34 PM | #1 |
Rock Stacker Join Date: Feb 2009 Location: Beaver Falls Pa
| SCX-10 aluminum truggy
I'm going to build some true aluminum truggy chassis for the scx-10 based rigs, what are some other bodies you guys are running on the trail honcho other than stock? I bought a new RTR honcho just for a pattern and for measurements needed The first step was to make the connection plates with sliders for the truggy cage Than I needed a weld jig Thats it for now, I will start working on the truggy cage, any suggestions or ideas would be appeciated |
01-19-2017, 11:27 PM | #2 |
Rock Crawler Join Date: May 2013 Location: Uniontown
| Re: SCX-10 aluminum truggy
I'll probably be turning the RC4WD Expedition Jeep into a truggy, and I know a few people who have NuKizer truggies who might like the additional scale points. That Proline Toyota would be a hot ticket as well. Sent from my XT1585 using Tapatalk |
01-21-2017, 09:04 AM | #3 |
I wanna be Dave Join Date: Aug 2006 Location: under a rock and a hard place
Nice set up !
01-21-2017, 02:21 PM | #4 |
Rock Stacker Join Date: Jan 2017 Location: Maui
The proline sr5 would be awesome. Also a tamiya/rc4wd hilux cab with truggy cage would be great. Sent from my SM-G920V using Tapatalk |
01-22-2017, 09:43 AM | #5 |
RCC Addict Join Date: Feb 2005 Location: Vancouver Island B.C.
I like your bender setup, have you tried it on steel tubing?
01-23-2017, 09:27 AM | #6 |
| Re: SCX-10 aluminum truggy I was it a comp over the weekend and saw the proline chevy and Toyota on a stock honcho they fit and looked good, I will add 2 studs on front of my cage and drill 2 holes in the body, It will then come off by pulling 2 clips on the hood
01-23-2017, 09:37 AM | #7 |
| Re: SCX-10 aluminum truggy |
01-23-2017, 04:23 PM | #8 |
I started to make some parts for the truggy back, I will have to start making a weld jig to hold the parts to see how they fit |
01-26-2017, 04:56 PM | #9 |
Working on the weld fixture |
01-28-2017, 04:17 AM | #10 |
Rock Crawler Join Date: Feb 2010 Location: chin ckeck
Very nice. How much will these sell for?
01-28-2017, 07:09 AM | #11 |
Can't wait to see this in person at the comp next month! Sent from my XT1585 using Tapatalk |
02-02-2017, 04:37 PM | #12 |
I found time to get the cage fit and welded, now it's time to cut the truck in half |
02-02-2017, 06:10 PM | #13 |
Pebble Pounder Join Date: Nov 2016 Location: USA
02-02-2017, 06:23 PM | #14 |
Awesome work!!!
02-02-2017, 09:47 PM | #15 |
Wow. Just. Wow. Can't wait to see this in person. Sent from my XT1585 using Tapatalk |
02-03-2017, 04:53 PM | #16 |
I was surprised only 2oz more |
02-04-2017, 09:30 AM | #17 |
I'm very satisfied with the fit of the aluminum truggy cage, A matching front bumper is in the works, This new RTR scx-10 truggy will be sold with all the stock parts after I make all the patterns and jigs I need, I will make a few of these cages for sell |
02-04-2017, 10:11 AM | #18 |
Pebble Pounder Join Date: Apr 2013 Location: Penn Yan
Very nice Tig work!
02-04-2017, 10:43 AM | #19 |
Your welding is top shelf! Curious to see how it holds up. I would recommend some diagonal bracing right behind the cab. Ive done a bit of tube work using both 3/16" steel brake line and solid rod and it bends over time. I do run my stuff hard and they have taken big tumbles, bent tubing is the result. My trucks aren't heavy either so its not the weight that is doing the damage, just big falls
02-04-2017, 03:10 PM | #20 |
I made this aluminum tube chassis class 2 about 6 years ago, It's bin comped hard and I have not had any problem with the frame, If you drop a rig high enough on to something hard enough something has to give, I will do some testing on brake line, solid 3/16 rod, and 6061 1/4'' aluminum, I could add some bracing, just trying to keep the weight down |
SCX-10 aluminum truggy - Similar Threads | ||||
Aluminum truggy chassis? | cooterwrenchen | General Scale Talk | 15 | 04-14-2013 10:51 PM |
SCX Truggy | $Truggster$ | Axial SCX-10 | 3 | 01-31-2010 02:00 PM |
