Thread: Tubed clod
Old 01-27-2017, 01:50 PM   #1
Default Tubed clod
Had this for a while never made a post on it. Ive bought and sold tons of rig, but this ones here to stay.
I picked it up on here for a bill n half. Absolutely loved it. This was also about 2 weeks before a local g6. I had no axles, electronics, wheels, tires, just a bare cage, body, dummy winch and skid.
Now, unfortunately I dont have pics of tearing it down, sanding, painting and assembling it all.
But here is a list of the changes
-Body-beat used and abused (light blue)
Now bondoed, sanded and painted purple!
-Scrapped up these parts off a buddy;
trans complete
axles with beef tubes complete
driveshafts new style wb8
hobby shop(s) parts
-strc links 2 sets of fronts (needed the lengths)
-misc screws and bearings
-1.9 racelines, proline K02s
-rc4wd winch and controller
heres a teaser so the first post isnt longgg
Sent from my SM-G928P using Tapatalk
Jfrisch01 is offline   Reply With Quote
Old 01-27-2017, 02:06 PM   #2
Default Re: Tubed clod
Now the parts come,
mmp sensored esc
roc412 3100kv
savox servo 400+oz
robinson racing gears for the trans
ssd pro knuckles
ssd ss steering links
rear tail lights, front lights in gmade light buckets, rock lights in front wheel wells
All together with new bearings, beef tubes, fresh grease, front and rear winches. And its off to Arkansas g6 with the family.
Old 01-27-2017, 02:15 PM   #3
Not to mention all the links are custom cut, tapped and re threaded to length. (started with strc links)
Has twin hammer vp trailing arms
K bess limit straps
2 winches
Front, rear, and rock lights
Delrin Cms mount
Doors are cut and notched
Cowl hood
Pinched front end
Dovetailed bed (whats left of the bed)
Theres a lot of custom parts so it cannot just be bought for it, I HAD to make a scale dash.
Couple trys, lots of glued fingers, bondo, sanding, black boogers from painting in my shed when its 40*. Finished product
Got ahold of a buddy to make me some decals, excellent turn around and quality
sorry for thoe crappy pic
Old 01-27-2017, 02:20 PM   #4
Some new wheels for her and and some brass knuckles*
And some misc pics from trail runs, house crawling etc
Old 01-27-2017, 02:20 PM   #5
Wow, awesome build. I really dig the work on the half doors.
justinart24 is offline   Reply With Quote
Old 01-27-2017, 02:25 PM   #6
And for the final updated pic of it, before anything else changes it.
This was kind of a mad dash to get everythinf detailed of whats changed, customized etc but if you got questions let me know. Comments are always welcomed.
Currently working on the floor, seats, windshield, door panels. Probably gonna be a while until those are completed though. And it needs to be re sanded and re painted as well.
Thanks guys for looking and now that its posted ill keep it up to date.
Old 01-27-2017, 02:26 PM   #7
I cannot take credit for those, or the cowl. Whoever did it I thank them as well cuz they are very well done. And thank you sir
Old 02-06-2017, 12:19 PM   #8
couple pics from a recent trail run. Took home some body damage :(
Cant forget the sons orange ax10! He loves this hobby and makes it even more fun!
Old 02-11-2017, 06:48 PM   #9
Spulln is offline   Reply With Quote
Old 02-13-2017, 08:38 PM   #10
Very nice! That paint color just works. What type of wheels are those?
Highmark is offline   Reply With Quote
Old 02-15-2017, 07:09 PM   #11
They are Fuel, chinese knocks though. The paint was suggested by a friend and it just worked out lol I would have never done purple haha. Thank you!
Old 02-16-2017, 10:18 AM   #12
Got me some sweet shots last weekend. Enjoy! Had a few trail damages along the way though. New body coming soon.
Going to do a tear down of the entire truck. Trying to find a little bit stronger paint I can use on the cage to keep from scratching off so easy. Also new body will most likely have the cowl off this truck, cut out and installed on the new body. I will have a windsheild on the new body, hopefully keep the body together a little more.
Possibly gonna get tko axles as well. Well see.
Old 03-06-2017, 06:20 PM   #13
Ended up with SSD axles. I like them alot. Can get to the diff now, just taking the cover off. They look awesome.
Body took some abuse :( ive got another on the shelf im going to get started on asap for the g6 in st louis april 7-9.
Ended up snapping a cvd out on the trail this past weekend.
Vanquish vvds, locked up f1 spools on the way as well!
Old 03-08-2017, 03:37 PM   #14
This is a new one for me. Cutting hardbodies with COTTON! Yes thats a fact, you can cut hardbodies with string. I have some from a sewing kit the wife had laying around. It can cut pretty accurate and with a very small line.
Worked good in my opinion, any only took about 5-10 minutes to get all the way though.
Got my f1 spools, vanquish vvds, and brand new 1.9 rock beasts ready to go on once I get more done with the body.
Ill now chop the bed sides off, Take all the accessories off and start on pinching the front.
Old 03-08-2017, 04:38 PM   #15
Very nice!
Ltd.yfz is offline   Reply With Quote
Old 03-08-2017, 07:01 PM   #16
Also got some halo green lights drilled out in the grille. Going to order a billet style grille and bug guard. Most likely at sun visor too. The old body was pinched in the front but I took out the front wheel well tubes so I can run a full size body and grille.
Have the bed cut out and its ready for bondo sanding and paint.
white bright lights
flip the switch and green halos!
Old 03-10-2017, 06:05 PM   #17
Threw some paint on it, tamiya metallic blue, wet look clear. Still need to paint the white stripe, white with tamiya pure white.
Not to bad, body isnt mounted.
Old 03-13-2017, 09:56 AM   #18
Took it out and beat it up pretty good. Was def not easy on it.
Everything driveline wise is still holding up. Surprisingly still running stock diff gears and they are holding up with new spools attached to them.
Vvds hardly look worn, and on a brand new set of tires thats good, considering the tires have tons of wear on them. The rocks were very porous and grippy, made for a very good day of crawling.
I did get a little wild, hit some jumps. Ended up braking one of the bottom screw hole tabs on the body :( but other than that its good.
Before it went out
A whole lot of beautiful parts. SSD, vanquish, rc4wd, tss, savox, oh and a missing beadlock screw
Old 03-19-2017, 01:11 PM   #19
I got tired of messing up a brand new hard body, I decided to get a lexan body and figure out how to cut it to fit. It could only be 9inches from front end to bumper due to the cage work. So no extended cabs, or large honcho style cabs. I did find a c10 chevy body for a tmaxx, it was 9.5 to the bed. Little snip snip here and snip snip there I got it to fix.
Threw the same style paint colors on as the clod body. I figure this will also help with weight.
Finished mounting it all up last night. Body mounts with velcro down by the sliders and bed screws into the cage, same as the clod body. Trying to keep it where I can just swap bodies quickly and easily.
One for show one for bashing, hard crawling lol.
Old 01-22-2018, 05:07 PM   #20
Starting back up on this one! It’s been in a tote out in the shed for months. With the G6 coming up I’m going to do my best to make this thing sick!
Already have the wheels and tires for it. Have to rob them off my Venture but it’s already got a few different sets anyway.
Going to strip/ sand/ polish and have the cage powder coated. Not sure on color yet but possibly a gun metal.
Have to source a new trans, and body. Other one has far too many cracks to fix.
I’ll post more once I get some progress on it!
Tubed clod - Similar Threads
Custom Tubed Clod twisted crawler Tamiya Clod Buster 2 11-21-2010 03:58 PM
