02-04-2017, 04:00 PM | #1 |
Rock Stacker Join Date: Jan 2017 Location: Houston
| Second run already broke.!
So I was wheeling my scx10 in some loose dry dirt and I guess dirt got into the motor and now the motor spins but will not connect to the gear inside to make the truck go, it catches every once in awhile but that's it. Is it stripped or just dirty inside.? Help!! Not very happy seeing as unspent $400 for this rig. MyGreenScx10 |
02-04-2017, 04:19 PM | #2 |
| Re: Second run already broke.!
Open it up and use your eyes.
02-04-2017, 04:23 PM | #3 |
Thanks for the advice... MyGreenScx10 |
02-04-2017, 04:29 PM | #4 |
It's possible the pinion gear has come loose... so I'd check that first. But it's more likely the transmission's plastic idler gear has stripped. The Trans. plastic idler gear strips easily if the slipper clutch is too tight. Metal (steel) transmission gears fixes that fault permanently regardless of if the slipper clutch is set too tight or eliminated altogether. |
02-04-2017, 04:30 PM | #5 | |
| Re: Second run already broke.! Quote:
MyGreenScx10 | |
02-04-2017, 04:48 PM | #6 | |
There are others that cost less coin. But I prefer Axial's machining - quality. http://www.axialracing.com/products/ax30708 They can be had for less then Axial's suggested retail price if ya google that. Think I got mine off ebay or maybe it was a vendor here. Axial - http://www.rpphobby.com/product_p/ax30708.htm Other options... Hot Racing - http://www.rpphobby.com/product_p/hotsscp1000t.htm SSD - http://www.rpphobby.com/product_p/ssd00172.htm The SCX-10, Wraith, AX-10 are all compatible and share the same trans. gears. Last edited by TacoCrawler; 02-04-2017 at 05:09 PM. | |
02-04-2017, 04:54 PM | #7 | |
MyGreenScx10 | |
02-04-2017, 05:13 PM | #8 |
| Re: Second run already broke.! |
02-04-2017, 05:15 PM | #9 |
So this is the culprit. MyGreenScx10 |
02-04-2017, 05:16 PM | #10 |
| Re: Second run already broke.! MyGreenScx10 |
02-04-2017, 06:31 PM | #11 |
Metal gear kit already ordered will be here in 2 days.! Thanks for the help.! MyGreenScx10 Last edited by Greendeadbolt18; 02-04-2017 at 06:35 PM. |
02-04-2017, 06:55 PM | #12 |
Welcome to the world of Axial. I'm glad you got the metal gears and not replacement plastic gears. That's pretty much a must-have upgrade unless you like opening your transmission to replace the plastic case a couple of times a year.
02-04-2017, 07:00 PM | #13 |
Lol I've never even taken my transmission apart without first removing that from the skid. guess ya can. tho' I'll still likely just remove it anyways. Last edited by TacoCrawler; 02-04-2017 at 07:03 PM. |
02-04-2017, 07:19 PM | #14 |
Rock Crawler Join Date: Jan 2017 Location: DownUnner
Sounds like the pinion spur mesh. Happened to mine on the second battery. I just pushed it together and retightened it and it's been A1. I'm running NiMH though the truck has probably had 20-30 hours of driving and potentially has travelled 50+ kilometres. Sorry just saw your post! Bad idler gear. Last edited by CoolRunning; 02-04-2017 at 07:20 PM. Reason: Update |
02-04-2017, 07:31 PM | #15 |
What do you think happened to cause it to strip like that? 3S? Big motor? My son did one but was abusing the car at the time with a friend (holding the car down and madly going forward and backwards whilst the other child pushed the car in the opposite direction). |
02-04-2017, 08:06 PM | #16 | |
MyGreenScx10 | |
02-04-2017, 08:08 PM | #17 |
My truck is completely stock and brand new. I've had it for 3 days. Lol. And my battery I only a 5000mah 30c. So nothing major I wasn't even wheeling hard either and it just stripped out. Guess just a bad manufatctured gear.? Plus the plastics are weak. Lol MyGreenScx10 |
02-04-2017, 08:12 PM | #18 | |
02-04-2017, 08:13 PM | #19 |
02-04-2017, 08:24 PM | #20 |
| Re: Second run already broke.! ...that's correct tho' something else in the drive line might break instead !? Lol But I can attest to those steel gears holding up to 3s use. But if one of the trans internal bearings fails... it can still be bad news and mess up those steel gears. So don't expect those bearings to survive forever... they won't Last edited by TacoCrawler; 02-04-2017 at 08:28 PM. |
Second run already broke.! - Similar Threads | ||||
What have you broke? | P-J | Axial Yeti | 38 | 03-17-2015 03:41 PM |
Need help i broke it! | pajey | Traxxas Crawlers | 22 | 05-11-2013 01:07 AM |
Don't ask how i broke it | losikid | Chit Chat | 12 | 11-16-2011 06:44 PM |
Broke It ! | twisted | Non Crawler RC's | 12 | 01-26-2009 03:59 AM |
broke her in.... | twisted | General Crawlers | 2 | 09-07-2006 11:48 AM |
