02-05-2017, 10:42 AM | #1 |
Quarry Creeper Join Date: Mar 2016
| Mighty FC body
So I'm getting ready to mount the Mighty FC body on my SCx10 Rubicon chassis. The Axial site says it is designed for the 290mm wheel base. Mine came stock 313. I have the hot racing link for 300mm now and the driveline angle is really steep. And when I put the links in to make it 290mm it going the be even steeper.anyway to lessen the angle? Sent from my iPad using Tapatalk |
02-06-2017, 03:51 PM | #2 |
Rock Crawler Join Date: May 2013 Location: Uniontown
| Re: Mighty FC body
Can you get a picture posted? Sent from my XT1585 using Tapatalk |
02-07-2017, 07:42 PM | #3 |
| Re: Mighty FC body I really want to mount the body on my SCX10-2 but can't find any short links. This body is for the 290mm (11.4) wheel base. The SCX10-2 is 313(12.3) wheelbase. The color is darker that I was looking for but I think it looks really good in the sunlight. Sent from my iPhone using Tapatalk |
02-08-2017, 06:48 AM | #4 |
| Re: Mighty FC body
I meant of the drive line, lol Sent from my XT1585 using Tapatalk |
02-08-2017, 07:34 AM | #5 |
| Re: Mighty FC body I hope these pictures help Sent from my iPhone using Tapatalk |
02-08-2017, 08:41 AM | #6 |
| Re: Mighty FC body
Looks like you need longer top links. Only a mm or two, could probably get away with a spacer. I thought in the other thread you wanted to use 10.2 AR44s? Nevermind, now I see you do have two chassis to work with, lol. Sent from my XT1585 using Tapatalk Last edited by Jeepy84; 02-08-2017 at 08:45 AM. |
02-08-2017, 10:19 AM | #7 |
Rock Stacker Join Date: Jan 2014 Location: Belleville, Ontario, Canada
| Re: Mighty FC body
can you swap out a couple rod ends ... either longer or shorter rod ends will assist with "clocking" your axle. longer rod ends on the upper links and shorter on the lower links may change your angles enough? not the best fix, but probably the cheapest, if you can get enough adjustment
Mighty FC body - Similar Threads | ||||
Mounting the Mighty FC Body | JPP | Axial SCX-10 | 14 | 01-21-2020 06:22 PM |
Mighty FC body | MX4141 | Paint and Body | 71 | 03-02-2019 10:21 AM |
New Jeep Mighty FC body.... | Hotrodvw | Axial SCX-10 | 14 | 04-12-2016 11:13 PM |
SCX/Mighty FC Body | MX4141 | 1.9 Scale Rigs | 2 | 01-22-2016 10:45 PM |
Got my Mighty FC body.....What color? | VTHokie | Axial SCX-10 | 86 | 10-11-2015 08:11 PM |
