12-28-2017, 03:28 PM | #1 |
Rock Stacker Join Date: Oct 2016 Location: Lake arrowhead
| Xr mod or gen 2 axles
I have a set of axles with vanquish vvd and vanquish inner and outer knickles with hd gears and titanium links, was wondering if changing to the new axles was really worth it vs going with an xr mod.. Thanks for any input
12-28-2017, 03:41 PM | #2 |
Pebble Pounder Join Date: Dec 2015 Location: Portugal
| Re: Xr mod or gen 2 axles
1st gen axles with narrow XR mod gives you great steering angle + underdrive/overdrive gearing options 2nd gen axles give you good steering + scale looks w/ front access to diff + better ground clearance I am in a similar situation as you but already did the XR mod - the fact that (as far as I know) there is no economic and/or reliable way to get UD/OD on the SCX10II axles makes it hard for me to justify changing to the new axles. Sent from my SM-G950F using Tapatalk |
12-28-2017, 09:21 PM | #3 |
I do like the look of the new axles, but is the fact that it is a hipoid cut gear mean that it will not be as durable for the size and will they handle the abuse of a sensored brushless combo.
12-29-2017, 02:27 AM | #4 |
RCC Addict Join Date: Nov 2016 Location: 1972 born Christian, Chinese.
Just follow your heart. I like the new axles, like it because it has small pumpkin and I could run Panhard Bar for scale look. |
12-29-2017, 08:12 AM | #5 |
I've spent so much time and effort getting my old V1 axles built, I haven't found much reason to buy the II axles. Smaller pumpkin is nice for sure, but hesitant to give up my OD/UD setup. Not to mention the cost for a set of II axles is just crazy. Lots of good options for $160-$200 |
12-29-2017, 08:49 AM | #6 | |
RCC Addict Join Date: May 2015 Location: Price Twp.
| Re: Xr mod or gen 2 axles Quote:
Because of the design they have multiple teeth in contact which provides them more strength then a straight cut gear. They are cable of high torque per square inch compared to a straight cut gear. The only reason they have not completely replaced straight cut gear is that they induces a thrust load and that they require high maintenance due to the constant need for lubrication to reduce the friction of the gears sliding as they mesh. Sounds like another rig is in order. Last edited by Ditchrat; 12-29-2017 at 08:52 AM. | |
12-29-2017, 09:13 AM | #7 |
[ Helical cut gears are used in high torque applications for the exact reason you are claiming they are not. Because of the design they have multiple teeth in contact which provides them more strength then a straight cut gear. They are cable of high torque per square inch compared to a straight cut gear. The only reason they have not completely replaced straight cut gear is that they induces a thrust load and that they require high maintenance due to the constant need for lubrication to reduce the friction of the gears sliding as they mesh.] I have no clue how to quot sorry. I say that because of the way a hipoid cut gear for a high pinion axle pushes away from the ring gear and a amboid cut gear pulls Its self towards the ring gear, I would think that with a plastic housing there would be skipping issues? I guess it depend on the direction the pinion is being driven but it is very interesting how they have scaled down a high pinion set up. Just coming form a real world side of thinking or maby I'm over thinking it. They do look great tho. Last edited by Evan Harich; 12-29-2017 at 09:23 AM. |
12-29-2017, 09:33 AM | #8 | |
I get where you're coming from. All these spare parts around its tough to make changes. The clearance on the new axles is very nice, its hard to beat that. | |
Xr mod or gen 2 axles - Similar Threads | ||||
Cheap fix / mod sticky in Gen Crawl.... | BENDER | Comments, Suggestions, and Help | 9 | 01-14-2005 05:27 AM |
