05-30-2018, 02:37 PM | #1 |
Rock Crawler Join Date: Jun 2008 Location: Clinton,Michigan
Havent ran my scx10 in a long while and getting back into it as I am finishing up a budget rig for my 6 yr old son. Dad is looking to spice up his old rig with some new stuff. Lol I was checking out parts and am thinking about picking up the ssd axle housings and the performance steering kit. Any known issues with weakpoints or such with these parts. I dont want to throw a bunch of money to get those parts working. I have a hand bros cms and panhard setup currently on rig. Does the steering kit actually give more steering? Running stock driveshaft in axle but prob bo to cvds eventually. This is steering kit I'm referring to. https://www.rpphobby.com/product_p/ssd00169.htm Any info appreciated on how well the parts work and hold up. And for fun figured I could share the rig in finishing up for my almost 6yr old son Last edited by THX_138; 06-04-2018 at 11:14 PM. Reason: Merged, posts minute apart |
05-30-2018, 02:37 PM | #2 |
Rock Crawler Join Date: Dec 2016 Location: Minnesota
| Re: Need some feedback/thoughts on ssd axle housing and steering kit
As far as steering angle improvement, until you swap out the dogbones that's going to be your limiting factor. Once those are gone you'll notice fairly substantial gains (or reduction) in turning radius. I'm a HUGE fan of SSD. Their parts and wheels are high quality stuff at a fair price. I go to them for upgrades first. I highly recommend that pro steering kit but I can't personally speak to their axle housings. I've had them on my list to try but haven't gotten them yet. I've heard great things about them though. Sent from my SM-G930V using Tapatalk |
05-30-2018, 02:42 PM | #3 |
Are you using the pro steering kit on stock axial housings? I see it says they can be used on stock. I figured the housings were fairly cheap,cool looking and mine are looking quite rough lol. Thanks for the reply btw |
05-30-2018, 02:48 PM | #4 |
Yup just using stock housings currently. I wouldn't be afraid to give the SSD housings a try. I'm just debating doing an AR44 swap on it next. If I don't, the SSD's are going on. Sent from my SM-G930V using Tapatalk |
05-30-2018, 02:57 PM | #5 |
Rock Crawler Join Date: Dec 2009 Location: Suffolk
I'm using the SSD axle housing, CMS kit, and pro steering conversion with Axial CVD's. The difference was huge. You have to have to CVD's though as said before. The truck turns 150% better than stock. You will have to adjust your drag link length a few mm to get the steering dialed in at zero trim. I used axial aluminum spacers on either end between the rod end and link. Untitled by JASON MCKIMMEY, on Flickr |
05-30-2018, 04:51 PM | #6 |
| Re: Need some feedback/thoughts on ssd axle housing and steering kit |
05-30-2018, 11:41 PM | #7 |
Newbie Join Date: Nov 2017 Location: Ethridge
Plus one for the housings & cms kit. Using stock internals.
05-31-2018, 07:04 AM | #8 |
Rock Crawler Join Date: Oct 2015 Location: Kristiansand
I have the d60 axle housings, and also the diamond axles. Very happy with all of them. No issues. Sent from my SM-G930F using Tapatalk |
05-31-2018, 10:26 AM | #9 |
D60 housings are great, and the pro steering kit is awsome. The housings will accept all stock parts, and vice versa. My D60's live under my brushless 2 speed 2.2 tired F150. My current issue is keeping front cvd's alive. She blows them apart after an hour or so of trail running... |
05-31-2018, 02:08 PM | #10 |
Thanks for all the replies guys I went ahead and pulled the trigger on ssd housings, axial cvds,ssd steering kit,flanges for knuckles, and a whole new bearing kit since I was redoing axles already. Cant wait !! Anybody got a pic of their steering at full lock with the steering kit and cvds. Curious to see how much of a change over stock I can expect Last edited by THX_138; 06-04-2018 at 11:13 PM. |
06-14-2018, 10:23 PM | #11 |
So apparently the steering kit wont work with axial 8 beadlocks?? I guess I need some wider hexes than the stock aluminum ones? The rod ends rub the tire and hits the beadlock screws really bad? Little irritated that ssd claims it works with all wheels
06-14-2018, 10:49 PM | #12 | |
| Re: Need some feedback/thoughts on ssd axle housing and steering kit Quote:
what knuckles are you using? I have found that the axial high clearance knuckles fix the issues of rubbing against the wheels in every instance I have had... usually I was running the VP 8* knuckles that rubbed against the wheels/tires on the inside. | |
06-14-2018, 11:07 PM | #13 | |
Sent from my SM-G955U using Tapatalk Last edited by discgolferlee; 06-15-2018 at 05:47 AM. | |
06-16-2018, 05:30 AM | #14 | |
Sent from my SM-G930F using Tapatalk | |
06-17-2018, 05:10 PM | #15 |
Dang, that stinks. I'm using the Proline Denali plastic beadlocks. They must have a little more offset than the stock axial. Edit: Confirmed with stock axial hexes, inside beadlock ring screws hit hard on the rod ends. Wider hexes? Last edited by JDM74; 06-17-2018 at 05:26 PM. |
06-17-2018, 05:13 PM | #16 |
Need some feedback/thoughts on ssd axle housing and steering kit - Similar Threads | ||||
SSD axle housing pinion bearing issue? | BigSki | General Scale Talk | 7 | 05-29-2018 11:16 PM |
axle housing upgrades? Thoughts? Help | Spencecrawler | Axial AX10 2nd-gen | 1 | 02-19-2017 09:28 AM |
SSD New wraith axle housing | Szczerba | General Crawlers | 180 | 03-01-2016 08:19 PM |
