Thread: Deadbolt to Hilux
Old 09-13-2020, 07:06 PM   #1
Default Deadbolt to Hilux
Got a nice deal on eBay for this Deadbolt. Want to change it up to a Hilux with a rear cage.
The guy did some nice mods. I need to sort out the front drive shaft. Make the front links just a bit longer to get the drive shaft angle better.
I have a SR410 receiver that I will use.
Got a Tamiya cab and metal grill to test out the look of it.
Lots of work ahead!
JP98 is offline   Reply With Quote
Old 09-16-2020, 02:22 PM   #2
Default Re: Deadbolt to Hilux
Today's update: Rear cage installed. New links up front. Made room for the battery tray by turning the front shocks around.
Old 09-19-2020, 07:10 AM   #3
Those drive shaft angles are pretty steep! And I thought mine were bad.
Phildirt is offline   Reply With Quote
Old 09-26-2020, 11:26 PM   #4
Yea, way too steep! Got any suggestions on how to fix. I could get longer upper links, but the tire angle gets weird.
Old 09-26-2020, 11:27 PM   #5
Some work today, put on side plates and getting ready to make the bolt holes for the cab.
Old 10-01-2020, 01:29 PM   #6
Almost done with the electronics. Added longer upper links and got the front drive shaft angle less steep.
Next is changing the lights from yellow to white. Will wire them up soon.
Old 05-10-2021, 08:00 PM   #7
Looks awesome, I’d like a hilux body on mine.
jsix321@yahoo.com is offline   Reply With Quote
Tags
hilux brushless
Deadbolt to Hilux - Similar Threads
Axial scx24 deadbolt beefed up vs stock deadbolt Rcing4life Scale Videos! 0 08-13-2020 07:55 PM
Deadbolt to hilux akatz Axial SCX-10 6 12-27-2015 01:20 PM
AX10 deadbolt body on SCX10 deadbolt BrianP Axial SCX-10 3 11-08-2015 04:51 PM
Axial scx10 deadbolt,jeep g6, hilux, wraith, r1, plus more TAFF1969 Scale Videos! 0 08-06-2014 12:02 PM
