![]() | #1 |
Rock Crawler Join Date: Mar 2016 Location: HB
Anyone have issues with the servo hot screw hitting the panhard? Took my friends rig out for the first time and with his Hitech servo, the screw backed out and stripped the servo horn. We noticed the rod end on the panhard contacted the screw when the suspension was fully compressed. Haven't seen this issue pop up so I'm hoping it was just overlooked and not tightened all the way down on install
![]() | #2 |
Newbie Join Date: Feb 2013 Location: Kempsey
i think a few people have mentioned issues with clearance here, I know I had to put some spacers under my servo with an alloy horn so that it would clear nicely.
![]() | #3 |
Rock Crawler Join Date: Nov 2013 Location: In the country
HI, There is a lot of mention here somewhere. But racers edge is the go to servo horn and I have seen washers used to raise as well. But racers edge servo horn is the predominant response. |
![]() | #4 |
Quarry Creeper Join Date: Feb 2015 Location: Corpus Christi
Always use threadlockers on servo horn screws. Sent from my XT1585 using Tapatalk |
![]() | #5 |
Thanks. Not sure if loctite was used the first time but definitely was this time. I'll look into adding spacers
![]() | #6 |
I wanna be Dave ![]() Join Date: May 2015 Location: Moving
Or you can switch to a Revo rod end on the upper panhard end. It's allot smaller than the Axial rod end and gave me clearance at full compression. Spacing the servo up isn't ideal because it takes the drag link and panhard bar out of parallel and will create bump steer. I'm also running the racers edge horn which is a nice low profile horn.
![]() | #7 |
Pebble Pounder Join Date: Apr 2007 Location: shadyside
no Loctite but a small lock washer will do the trick an definitely spacers under my savox servo, an a racers edge aluminum horn
![]() | #8 | |
| ![]() Quote:
Sent from my LG-D850 using Tapatalk | |
![]() | #9 |
Quarry Creeper Join Date: Aug 2015 Location: Worthington
Adding the same amount of spacers between horn and link will keep everything inline
![]() | #10 |
Quarry Creeper Join Date: Jun 2014 Location: Grand Haven, MI
I just want more throw. I already have the racers edge horn on there, but there is plenty of throw left. I need a servo horn that is 2" long lol. And yes, my EPA is all the way up.
![]() | #11 | |
Rock Crawler Join Date: Jul 2011 Location: palm desert (southern cali)
| ![]() Quote:
You need a different radio then I'm using a cheap tactic 3 channel hitec 7954sh and the metal horn that comes with hitec servo I have it set at max before bind and can still go more Sent from my iPhone using Tapatalk | |
![]() | #12 |
| ![]() You were right! I tried a flysky instead of my Kyosho radio and the flysky had much more travel. Now I'm bummed. I wanted to use the kyosho since it has a 3 position switch on it. I want to do the 2-speed later on. I guess I have to choose between less steering, or 2-speed. I guess I could always get another radio (don't want to).
![]() | #13 | |
| ![]() Quote:
![]() | #14 |
It appears I can do a 2-speed with my flysky. I just can't control a winch. I'm not really into winching, I had one a while back and hardly used it. So, it looks like I'm going with the Flysky for now.
![]() | #15 |
Cool well sounds like you got it sorted out nice Sent from my iPhone using Tapatalk |
OFNA Servo Horn stout enough for Protek 170T Servo? | Banjoblue | Axial Wraith | 2 | 06-25-2015 05:30 PM |
Wraith servo horn clearance? | StomperCrawler | Axial Wraith | 6 | 12-09-2014 03:39 PM |
