07-27-2016, 11:04 AM | #21 | |
| Re: Lots of transmission/spur play!? Quote:
I had the same play in my transmission, and then took it apart and put it back together with better attention to detail. What do you know, it was fixed when I spent a little more time following the instructions The long plastic spacers are pretty important. | |
07-27-2016, 12:06 PM | #22 | |
Quarry Creeper Join Date: Jun 2014 Location: Grand Haven, MI
What they should have done though is made a single speed trans housing come with the kit, and then make the upcoming 2-speed completion kit come with a larger 2 speed housing. It is a massive transmission for sure. I had to modify my proline FAUX INTERIOR because it was getting hung up on the top of the slipper cover area. Good luck going full interior with that giant hunk! Not happening! But again, if that is your goal you can slap the old trans in it. | |
07-27-2016, 02:52 PM | #23 |
Quarry Creeper Join Date: Aug 2015 Location: Worthington
The plastic spacer is the to keep the gear on the pin but the play in the top shaft is the shaft sliding out till the pin hit the bearing. Wondering if you could drill small hole in the spacer to match up with the unused hole in shaft to take up the play
07-27-2016, 03:32 PM | #24 | |
2 speed? Again, 2 points to make here are 1. 2 speed is pointless in a scaler IMHO. Go brushless if you want a bunch of wheel speed or buy the right motor for your application. Why would I need this trans, another servo, and the 2 speed kit that wasn't included so I can choose between going 3mph or 5mph. Is it really worth it? 2 speed is great for showing everyone in the staging area that you have 2 speed then running the rest of the day in second gear because you know it really is pointless. Secondly, there are other 2 speed transmissions on the market that are half the size and strong enough to handle a 15 pound truck on 6s. Last edited by SCREAMER; 07-27-2016 at 07:31 PM. Reason: Spelling | |
07-27-2016, 04:25 PM | #25 |
So you complain about having to go aftermarket to flip the trans, and then follow that up with "if you want 2 speed go aftermarket?" I think you got a bit of axial angst in ya, bro. ;) |
07-27-2016, 07:30 PM | #26 |
You're confused. First, I'm not complaining at all about having to go aftermarket to flip the trans. I said it was pointless to do so since the 1 pro doesn't out weigh the many cons. Second, The other 2 speed transmission I was referring to is in an RTR vehicle that is better designed, stronger, smaller, and actually come as a 2 speed, not 2 speed ready whenever Axial gets around to it.
08-07-2016, 02:07 PM | #27 |
Rock Stacker Join Date: Aug 2014 Location: Columbus
I feel guilty that I'm just now getting around to assembling this kit, but I'm not having this same problem with my transmission. Those who got replacement parts from Axial, did that fix the problem? If so, what was changed? What parts should I ask them for?
08-07-2016, 04:57 PM | #28 |
Just thinking out loud here... If the top shaft play is just the shaft sliding back and forth until the gear pin bottoms out to the ball bearing, couldn't you just make some tiny plastic wedges (say trim a tab off a parts tree) and just jam it in the gear slot to take up the slack between the pin and bearing? |
08-07-2016, 05:08 PM | #29 |
This isn't my video, but here's the exact problem I'm having with the transmission: https://www.youtube.com/watch?v=Mr-d6Ru5JFE Which I don't understand, because the top shaft seems to be perfectly straight. It's not supposed to do that, is it? |
08-07-2016, 05:19 PM | #30 | |
I wanna be Dave Join Date: Sep 2012 Location: Victoria, BC
08-07-2016, 05:38 PM | #31 |
Thanks, I read your post and it was very helpful! However, I thought Axial might have a better official solution that doesn't require me to go out and track down a washer with those exact dimensions. Where did you get your washer?
08-07-2016, 09:47 PM | #32 |
Pebble Pounder Join Date: Oct 2012 Location: Canada
No shimming will fix this, the hole for the cross pin is drilled in the wrong spot. The bearing, gear and spacer fix the case perfectly, the play is the movement of the shaft and pin in the gear crosspinn pocket |
08-07-2016, 10:07 PM | #33 | |
There's two issues at hand, the spur wobble and the in/out slop of the spur shaft. | |
08-07-2016, 10:48 PM | #34 |
Newbie Join Date: Mar 2016 Location: Vancouver Island
The black axial hub washers work well for this purpose.
08-07-2016, 10:59 PM | #35 | |
Newbie Join Date: May 2016 Location: Truckee
This was my first kit and RC. glad I went with Axial on this. customer service has been outstanding. anyway I agree that it could be that center bushing. I am going to try the washers as well. Last edited by SPRDave; 08-08-2016 at 12:11 AM. | |
08-08-2016, 01:19 AM | #36 |
| Re: Lots of transmission/spur play!? That is what I am talking about. Wedge a spacer into the gear pin slot between the pin and the bearing.
08-08-2016, 06:26 AM | #37 | |
08-08-2016, 07:12 AM | #38 |
Taking away the in and out play is quite easy, it just requires shimming in front of the first bearing. I took the spare plastic transmission spacer on the parts tree, cut a 5-6 mm spacer (I didn't get an exact measurement while I was building), installed it on the topshaft in front of the bearing, then assembled the trans per the instructions. Boom, no more topshaft play using only parts from the box. |
08-09-2016, 06:14 PM | #39 |
| Re: Lots of transmission/spur play!? |
08-09-2016, 06:25 PM | #40 | |
This, however, took out all the slop. | |
Lots of transmission/spur play!? - Similar Threads | ||||
Play between front and rear outputs on transmission? | cizardev | Vaterra Ascender | 14 | 01-28-2016 10:04 AM |
Lots of play in my SCX10 axles? | Derekuda | General Crawlers | 5 | 09-09-2015 10:02 PM |
TF2 transmission slop/play | Expat Crawler | RC4WD Trail Finder 2 | 11 | 04-03-2014 01:43 PM |
I have play in the slipper/spur unit | nafie | Axial SCX-10 | 2 | 09-18-2010 12:12 PM |
