09-03-2016, 04:40 PM | #1 |
Quarry Creeper Join Date: Mar 2016
| 2.2 tires Was hanging out at my local hobby shop. Threw a set of 2.2 BFG All Terrains in. Looks good but then I'd have to hack the flares off. Put the stocks back on. Sent from my iPhone using Tapatalk |
09-03-2016, 06:50 PM | #2 |
Quarry Creeper Join Date: Dec 2013 Location: Swartz Creek ~ MI
| Re: 2.2 tires |
09-03-2016, 11:53 PM | #3 |
Quarry Creeper Join Date: Mar 2014 Location: Rogers, MN
| Re: 2.2 tires
Although not on my SCX10-2, but still the body from it (shortened it to a 2-door) is on my 2.2 comp truck (scx10 rear axle, narrowed AR60 up front). I run the shorter Proline Super Swamper TSL (5.4") and they fit inside the wheel wells nicely. -Derek |
09-04-2016, 07:07 PM | #4 |
Pebble Pounder Join Date: Mar 2016 Location: Pacifica
| Re: 2.2 tires
Wow Derek two very nice trucks I'm not a Ford guy but i would rock that body for days, and as for your work on that Jeep? When are you going to do a how to video on shorting that Cherokee??? it looks sick on those 2.2's And i have some love for that NuKizer 715 as well Stomper ~D |
09-07-2016, 03:44 AM | #5 |
| Re: 2.2 tires
Hey Stomper and SuperDrty would each of you tell me what brand and size SLW hubs each of you have on your Pro-Line 2.2 wheels? I have the same wheels as both of you and i need to order hubs. Thank You, ~Darris |
09-07-2016, 06:33 AM | #6 |
| Re: 2.2 tires
I'm using Axial plastic hubs for the Yeti, the wide ones out back on a stock width scx axle. My front axle is wider so I run the narrow hub up front
09-07-2016, 09:19 AM | #7 |
| Re: 2.2 tires
HI ( Say What ) , This is what I am useing for Tires / Wheels & Hubs Pro-Line Interco TSL Super Swamper 2.2" G8 Tires - 5 1/4" Tall Pro-Line FaultLine 2.2" Blk/Blk Bead-Loc Yeti F/R Vanquish SLW 350 Wheel Hub's (2) Sets Vanquish SLW Hub Screw Kit - (2) Packages (24) Total Or scale screw's that look like real lug nuts. - Them are what I am using now. And you have to buy a special tool to install them so it can get a little pricey. Just To Note: After running my truck with that setup above, I had to do a lot more modification's. Then just putting on 100mm shocks. I had to trim the under pans that the sliders mount to. More trimming of the body & had to raise the body some. Starting to think if it was really even worth going with 2.2 tire's at all now. Will have some Up-date pics soon. |
09-08-2016, 08:08 AM | #8 |
RCC Addict Join Date: Sep 2009 Location: sacramento
| Re: 2.2 tires have any more pics of the body mod looks great
