09-15-2016, 04:11 PM | #1 |
Pebble Pounder Join Date: Apr 2013 Location: SoCal
| Sidehilling
Hello, I need assistance on side hilling my truck sucks at it. I'm running the stock tires with metal rims, and CI foams. Stock shocks and springs, very minimal stuff on the roof rack (sand ramps, sleeping bag) |
09-15-2016, 05:06 PM | #2 |
Quarry Creeper Join Date: Feb 2015 Location: Corpus Christi
| Re: Sidehilling
You need to add weight down low. Maybe stiffen up the shocks for less body roll. Sent from my XT1585 using Tapatalk |
09-15-2016, 08:29 PM | #3 |
Rock Crawler Join Date: May 2013 Location: Uniontown
| Re: Sidehilling
Stiffen up the foams and springs in the rear, you want it as planted as possible without it being totally solid. When the front is flexy, the rear mustn't be or it will flop. Sent from my XT1585 using Tapatalk |
09-16-2016, 04:18 AM | #4 |
Rock Crawler Join Date: Nov 2013 Location: In the country
| Re: Sidehilling
ADD LCG, I find mine top heavy as well.
09-16-2016, 08:10 AM | #5 |
Rock Crawler Join Date: Oct 2015 Location: Kristiansand
| Re: Sidehilling
Use CI Deuces wild foams. Sent from my SM-G930F using Tapatalk |
09-16-2016, 08:35 AM | #6 |
RCC Addict Join Date: Jul 2009 Location: Ontherocks
| Re: Sidehilling
Mount the shocks outside of the mounts on the axle. Also increasing the track width will help as they are kinda narrow out of the box. |
09-16-2016, 09:09 AM | #7 |
Newbie Join Date: Oct 2010 Location: Your moms house...
| Re: Sidehilling |
09-16-2016, 10:14 AM | #8 |
| Re: Sidehilling
I still haven't added any weights to the wheels or anything. Ill try a little front wheel weights, and a stiffer rear springs. Don't want to make it wider fits in the fenders nicely now. I also have Crawler innovations dual stage foams.
09-16-2016, 10:03 PM | #9 |
Rock Crawler Join Date: Apr 2009 Location: bend
| Re: Sidehilling
I like 60% droop and super soft springs with 2000 weight shock oil. Slow the shock down. How are you running your shocks ???
09-18-2016, 05:49 PM | #10 |
Newbie Join Date: Sep 2016 Location: Texas
| Re: Sidehilling
Make sure the foams are correct. Im not a fan of the 2 stage(I'm a slow go guy) A little thicker oil and droop.
09-18-2016, 06:02 PM | #11 |
Quarry Creeper Join Date: Apr 2013 Location: perkasie
| Re: Sidehilling
For me adding weight down low either in the tires or on the axles somehow and definitely better foams.....harder foams for me usually help due to.my rigs being heavy to begin with. Sent from my SAMSUNG-SM-G891A using Tapatalk |
09-19-2016, 02:31 PM | #12 |
| Re: Sidehilling I'm running my shocks with the stock kit oil, and springs. I'm running the collars all the way up and no preload. I'm running CI foams with comp cut inners, and medium outers.
Sidehilling - Similar Threads | ||||
Sidehilling, or the lack of.... | cgw | Vaterra Ascender | 25 | 12-05-2015 01:38 AM |
Rear tire lifting while sidehilling! | Tgreer | General Crawlers | 7 | 02-03-2012 12:43 PM |
Sidehilling Angle | Harvo | General Crawlers | 22 | 04-12-2010 05:54 PM |
sidehilling? | jaycruz | Axial AX-10 Scorpion | 13 | 05-19-2008 03:25 PM |
