11-03-2017, 07:36 AM | #1 |
RCC Addict Join Date: May 2015 Location: Price Twp.
| General SCX10ii trans questions.
I have a couple SCX10, which have enough upgrades already done to them that they perform as well as a duce, well at least the ones I have seen. That being said it is time for another winter project, and the deuce seems like a good starting point. That point has been settled and I am collecting parts prior to buying a kit. With out the kit in hand, the best I can do is reading. Either some things are unclear or I just want confirmation, so I am reaching out to you guys. Lets talk trannies. I really want to put a dig unit in the rig, more as a novelty to be honest. I like the idea of disengaging the rear on climbs where torque and traction lifts the front. Of coarse I want to play around with locking the rear. From what I am reading, if I plan on using the VP dig unit, I need to switch to the rtr(same as scx10 right?) transmission. Kit will have the skid plate, but Ill need to buy new internals, going with a metal case regardless. If that is the case will there be any issues with the gear ratio that couldn't be addressed with pinion changes? (normally run 3s and a 35t, but may try brushless. So I can adjust any of that if needed) I am assuming that since its WB shafts size wont be an issue as I can cut them down if needed. |
11-03-2017, 10:37 AM | #2 |
Rock Crawler Join Date: Dec 2012 Location: Utah
| Re: General SCX10ii trans questions.
Vp digs are awesome ive been running them for years and they still work flawlessly! You will need a regular style SCX trans. I def recommend a alum case and either Vp Incision, SSD or HR internal gears! Take your time setting it up especially your dig servo end points and it will shift smooth as butter |
11-03-2017, 12:33 PM | #3 | |
| Re: General SCX10ii trans questions. Quote:
Will do I was going to spring for the VP only so the finishes match, I know right, stupid but its a treat not a needed part so. Have you run one in a deuce yet? | |
General SCX10ii trans questions. - Similar Threads | ||||
SCX10II Kit Trans Issues... | JSterrett | Axial SCX10 II | 9 | 03-12-2017 10:24 PM |
General G questions | Curcal | G-Made Crawlers | 1 | 06-27-2012 04:25 PM |
Just some general questions | Synthetic | Losi Mini-Rock Crawler | 6 | 11-29-2009 09:15 PM |
General 3 speed trans ??? | shierkahn | General Crawlers | 1 | 12-08-2008 08:55 PM |
