12-29-2017, 10:57 AM | #1 |
Newbie Join Date: Dec 2017 Location: Moncton
| Suspension upgrade on my SCX10 2
Hey fellas. I'm looking at upgrading my suspension on my SCX10 2 Cherokee. I have a leaky shock up front and it seems to bind back and forth so I think it may be broken inside. I'm very new to the RC world. I found a nice set of shocks on Ebay but I'm not sure if they're any good. The stock shocks on my rig are 90mms and these new ones are 110mms. Will I need to do any modification to make these work? I tried searching but the search button does not work. Anyone else having this issue? Thanks in advance. https://m.ebay.ca/itm/Axial-SCX10-Je...AAAOSwo4pYl~so |
12-29-2017, 11:26 AM | #2 |
Rock Stacker Join Date: Jan 2016 Location: US
| Re: Suspension upgrade on my SCX10 2
You will find many different opinions on shock choice. I am sure the shocks you have picked out are fine, but you are going to increase your ride height by quite a bit with them. Which will also decrease your stability out on the rocks without adding some serious weight down low to make up for it. If you would like to keep your stock ride height, the best bang for the buck in my opinion is the Traxxas Ultra shocks. Part number tra3760a, which is the same length as your stock shocks, is a fantastic option. They come already assembled. Just add whatever weight oil you want, and go. I have had great luck with them. They never leak, and I haven't figured out how to break one yet. But I will keep trying. For around $12 to $13 a pair, you can't go wrong. That's just my 2 cents. Good luck and have fun, cause that's what it is all about. Sent from my SM-G950U using Tapatalk |
12-29-2017, 11:40 AM | #3 |
RCC Addict Join Date: Nov 2014 Location: Nowhere
You're not the only one that had bad shocks on the 10.2, unfortunately Axial just continually has problems trying to make the stock shocks work. That said, I would avoid the 110mm shocks because you're going to lift the rig another 20mm and the springs have an unknown stiffness, which could be too stiff or too soft. I would sooner use something like the TRX-4 shocks, they're only around 90mm if I recall and I've used several sets of Traxxas aluminum bodied shocks and haven't been disappointed: TRX-4 Tactical Unit - SHOCKS (front rear dampers & Springs GTS Traxxas 82066-4 | eBay |
12-29-2017, 11:53 AM | #4 |
Rock Stacker Join Date: Sep 2015 Location: Brunswick Hills
Before you do anything determine if your shocks are just leaking or if they need repair. Take them apart and make sure the o ring is placed properly and then make sure you put a thin coat of shock grease ( green slime ) or even petroleum jelly on the orings and replace them. Refill with shock oil, bleed out the air bubbles and retighten them but do not overtighten them. Sometimes the shocks have not been properly built or have been over tightened which can cause leaks. Doing this costs very little and if you still have leaky shocks you at least have learned how the shocks are put together and how they work. I know shocks can be a pain at times but determine what the problem is and fix it if you can before just throwing hard earned money into a new shock that also could leak. Good luck and have fun learning how all the parts on your rc work !
12-29-2017, 12:22 PM | #5 |
Wow 13 dollars a pair? SOLD! is that off the Traxxas site? Do they come oiled already? Or I need to add the oil? I just came back from a run and noticed that my front shocks bottom out when the truck is just sitting there. That means my oil must of all leaked out?
12-29-2017, 12:43 PM | #6 | |
| Re: Suspension upgrade on my SCX10 2 Quote:
12-29-2017, 12:44 PM | #7 | |
Suspension upgrade on my SCX10 2 - Similar Threads | ||||
Suspension upgrade | Crawlernoob73 | Tamiya XC/CC01 | 5 | 12-10-2016 11:01 AM |
Suspension upgrade | Andyking | Axial Wraith | 2 | 11-13-2013 12:20 PM |
What suspension upgrade next? | HeavyG | Axial SCX-10 | 6 | 04-08-2010 07:43 PM |
Suspension Upgrade | Easy Target | Axial AX-10 Scorpion | 5 | 07-09-2008 08:27 PM |
