01-02-2018, 02:33 AM | #1 |
Newbie Join Date: Apr 2017 Location: Brisbane
| scx10 2 sitting uneven
hey guys, ive got an scx10 2 rtr, i upgrade the shocks to yeah racing desert lizards 90mm. after building the shocks they were the same length compressed and uncompressed. but when mounted the side the steering linkage sits on sits about 10mm higher than the other side is this to do with the panhard bar? anything i can do to remedy this? cheers! |
01-02-2018, 03:24 AM | #2 |
Rock Crawler Join Date: Mar 2016 Location: Zagreb, Croatia
| Re: scx10 2 sitting uneven
How's the weight distribution? You can put each corner on a scale and see if there's a big difference...
01-02-2018, 07:12 AM | #3 |
Rock Crawler Join Date: Mar 2017 Location: Rubicon Trail
When you lift the chassis does the axle remain uneven or does it even out? If not it may be the panhard. Sent from my iPhone using Tapatalk |
01-02-2018, 10:01 AM | #4 |
Quarry Creeper Join Date: Dec 2013 Location: Swartz Creek ~ MI
If the shocks are longer then stock your truck will set uneven. My truck sat uneven when I put on 100mm shocks on my SCX10 II All I did to solve the problem was to put some washers on the panhard bar as in the pic. Last edited by Stomper Fan 777; 01-02-2018 at 10:41 AM. |
scx10 2 sitting uneven - Similar Threads | ||||
After a year and a half of sitting around, my SCX10 Range Rover is finally together! | Brettka7 | Axial SCX-10 | 3 | 01-23-2017 04:38 PM |
uneven turning radius | danmac | Newbie General | 3 | 08-19-2012 01:42 PM |
New lipo always balanced charged still very uneven discharge? | spoo76 | Electronics | 13 | 11-02-2011 05:36 PM |
Uneven suspension links question..... | ToTheMAXXcrawler | General Crawlers | 3 | 01-08-2010 10:06 AM |
Uneven Steering | JoeSay | Axial AX-10 Scorpion | 10 | 09-21-2007 12:02 AM |
