03-08-2018, 08:12 AM | #1 |
Newbie Join Date: Mar 2018 Location: Halifax Nova Scotia
| Wheel weights for 1.9
What do you guys use as weights for 1.9 rims. Where can I get some? How much do you guys put in the front and rear?
03-08-2018, 08:20 AM | #2 |
Rock Crawler Join Date: Oct 2009 Location: Danish badlands
| Re: Wheel weights for 1.9
We are moving away from weight in wheels, spinning weight are not cool, so now we put weight elsewhere on axles. Brass C - brass hubs ASO |
03-08-2018, 08:37 AM | #3 |
That looks awesome and expensive. How much weight did that add per side?
03-08-2018, 08:47 AM | #4 | |
Newbie Join Date: Feb 2018 Location: US
| Re: Wheel weights for 1.9 Quote:
Sent from my Pixel XL using Tapatalk | |
03-08-2018, 08:53 AM | #5 |
Those add 46 grams each side, my carrier are ALU but you can also get those in brass. Brass hub carriers will add around 35 grams each side. https://www.rcsamix.com/index.php/fo...liper-set.html https://www.amainhobbies.com/samix-s...12fsbk/p728125 On the rear i have been a little creative with older parts, samix now have a kit with the brake calibers. This will add 61 grams in each side. https://www.rcsamix.com/index.php/fo...liper-set.html This are the one i have and then have modified to add the brake disks to. https://www.amainhobbies.com/samix-s...12fsbk/p728125 Then i have some brass beef tube parts ( links mount ) and a single diff cover in brass now on my rear axle. There are a range of heavy options from a range of brands. you could also use ALU axles they are generally some heavier than the original plastic parts. I have a SSD pro 44 axle in the front, plastic diff but axle tuber are steel, i intend to put a SSd axle in the rear too but that will have to wait a little. Last edited by Peaker; 03-08-2018 at 08:58 AM. |
Wheel weights for 1.9 - Similar Threads | ||||
Knuckle Weights vs. Wheel Weights | Harvo | Tires and Wheels | 34 | 11-16-2011 01:15 PM |
wheel weights | Manfjourde | Newbie General | 1 | 10-26-2011 11:11 AM |
wheel weights | Cj7easternshore | Losi Micro-Rock Crawler | 2 | 09-11-2011 05:17 PM |
Wheel weights.... | GixxerCrawler | Newbie General | 13 | 10-27-2008 01:53 AM |
wheel weights | Famo | Tires and Wheels | 1 | 09-16-2008 07:19 PM |
