03-13-2018, 05:50 PM | #1 |
Newbie Join Date: Jan 2018 Location: Buda
| Xtra Speed Jeep V2 body on SCX10ii
Anyone know what needs to be done to get the V2 version of the Xtra Speed Jeep body to fit on the SCX10ii? I'm thinking of getting one, but I don't want to have to cut up the body a bunch or completely rearrange the guts of the SCX10ii either.
03-13-2018, 07:51 PM | #2 |
Newbie Join Date: Sep 2009 Location: San Antonio
| Re: Xtra Speed Jeep V2 body on SCX10ii
Funny, wondered the same. I bought one today. Check youtube, Kingston RC has a few videos about his build. From what I have seen and read, it fits right up.
03-15-2018, 12:01 PM | #3 |
Newbie Join Date: May 2016 Location: Concord
I have one mounted on a SCX10, it looks like it would fit well on the SCX10ii with kit transmission being mounted in the stock rear position. That's just looking at the floor pan molding. It has mounting points cast into the body that don't line up to the front or rear positions, I'm not sure what chassis it's actually designed for. I made a small metal plate to match the body mounting points on the front and I'm using strong Velcro for the rear. You could use magnets if you're doing gentle trailing, but, the body is really solid and heavy as a result. I just realized there are three versions of xtra speed jeep JK unlimited bodies. I have the one below, which has a lower rear floor and different body mounting points. http://www.rcmart.com/jeep-hard-plas...d-p-74625.html Last edited by norcal-s; 03-15-2018 at 02:03 PM. |
03-16-2018, 07:53 AM | #4 |
I finally found a good video that showed the mods needed to get the body to fit correctly on a SCX10 ii RTR. Radio gear has to be moved and something has to be done with the gearbox casing. In this particular person's build, he removed the grey casing. Not sure where he is placing his radio gear. I think this is a no go for me since I would still like to throw my trail honcho body on when I know I'm going to be running hard rocky trails. |
05-09-2018, 10:50 AM | #5 |
Newbie Join Date: Oct 2012 Location: Statesville
I used one of the ebay jk hard bodies (pretty much the same as the xtra speed) and other than using magnets to attach i cut out the center console a bit to clear the tranny (dig tranny spun around backwards so the dig acts as a transfer case) and a small place for the motor terminal and dig actuator. Had to cut more than i originally planned to just to get the body down on the frame. I wanted it to look like a jeep with maybe a few inches of lift to clear the 37" Mud Thrashers. Used some styrene to fill in any holes, but with the interior painted black, u can barely notice it!! I'd like to post pics but i don't have a Photobucket acct or anything so until i do i can't post em up! I'll be sure to post back here when i finally do. My opinion.....GET ONE!!! Even if it doesn't fit easily, hell i think i enjoy the build better than the driving!!
05-09-2018, 10:52 AM | #6 |
BTW NORCAL-S's link is the EXACT body i used!! |
05-14-2018, 08:29 PM | #7 | |
Pebble Pounder Join Date: Dec 2017 Location: Pinehurst
You watched Ricks Scale RC I'd bet. He moved a bunch of stuff. I have seen it in person. But he hasn't revealed it yet in YouTube, so I won't mention. But a bunch of what he moved was because he just wanted to i think. Only minimum cutting was required to fit it on. Trim battery box, a little out of the console and a small spot in the driver side floor board by the transmission tunnel Quote:
Xtra Speed Jeep V2 body on SCX10ii - Similar Threads | ||||
I need help mounting xtra speed cherokee body on a scx10 | iluvny081 | Paint and Body | 1 | 01-22-2018 01:39 PM |
Xtra speed 334 wb | Frank211 | General Scale Talk | 2 | 01-19-2018 12:16 PM |
New Wrangler Unlimited Body from Xtra Speed | Digs1111 | Paint and Body | 28 | 12-18-2017 06:55 PM |
Xtra Speed Jeep Wrangler Body Kit | Digs1111 | Paint and Body | 0 | 08-30-2017 03:16 PM |
xtra speed rc | roughneck | General Crawlers | 6 | 04-06-2014 09:17 PM |
