07-10-2018, 09:40 PM | #21 | |
RCC Addict Join Date: Feb 2016 Location: Princeton, North Carolina, USA
| Re: Rek's Scale Trail Honcho Quote:
Sent from my SM-G930R4 using Tapatalk | |
07-10-2018, 09:54 PM | #22 |
Quarry Creeper Join Date: Nov 2015 Location: US
solid man. I can dig it.
07-10-2018, 11:31 PM | #23 |
Rock Crawler Join Date: May 2018 Location: USA
The truck is worlds better than it was stock too, its just such a joy to drive, now if this dang heatwave would stop and let fall come I could get out to use it more!
07-10-2018, 11:43 PM | #24 |
I've barely run my honcho ii. Maybe a full battery has been run through it on the rock pile I have in the backyard just getting used to the differences between the original and the ii. Last night we went to play out back on the petrified dune and it browned out the esc, because of the heat I'm guessing. It had maybe 15 minutes of run time on 3s before this happened. I let it sit for 15 minutes then plugged it back in and it seemed alright but I called today and was asked to send them an email regarding the issue, they suspect it got too hot. I guess we will see how they respond to my email
07-10-2018, 11:50 PM | #25 | |
07-11-2018, 12:29 AM | #26 |
im still running the ae2 on 2s on my original Honcho it has not ever overheated
07-17-2018, 09:56 AM | #27 |
Got these beauties in yesterday! |
07-17-2018, 10:36 PM | #28 |
you already assembled them? I just hung mine on the pegboard for future mind clearing sessions post forbidden twizzler. I am considering going further than I had planned with a brushless setup in my ii after the overheating. since I have the brushed torquemaster expert 21t in the OG Honcho I think i will jump up to 3s with it first to see how I like it but I grabbed the supershaftys for it also just in case. Thanks for pointing out when they came back in stock.
07-18-2018, 01:09 AM | #29 | |
07-21-2018, 06:34 AM | #30 |
Decided to upgrade my radio system to a higher channel setup, so I got a GT3C and hacked it. It was actually pretty easy once I found some good guides to follow. |
08-15-2018, 12:43 PM | #31 |
Ive since returned the SS shafts as they kept breaking, I have a bunch of parts coming tomorrow ill update with them then. For now though I got some awesome 12.9 screws from Tonys Screws! They didnt have a kit so I went through my manual and bought them all individually from him. Ended up around 38$ shipped, which was only 2$ more than the old SCX10 kit they had. |
08-15-2018, 01:22 PM | #32 |
breaking how so?
08-15-2018, 01:57 PM | #33 |
| Re: Rek's Scale Trail Honcho On normal MIPs the part that holds the pin is a cup that goes all the way around. SS machines 70% of that material away, and lo and behold they snap at the holes that hold the pins. Had it happen twice before the one man shop and I had a rather terse argument over the phone that resulted in me sending them back and getting a full refund.
08-15-2018, 03:25 PM | #34 |
| Re: Rek's Scale Trail Honcho Thanks, it really does go hand in hand with RC. Ive been slowly but surely working on a Garage Diorama with 3d printed parts, but it will likely take me till well into winter to get that finished. Too many chances to actually take my trucks out |
08-15-2018, 03:29 PM | #35 |
| Re: Rek's Scale Trail Honcho |
08-17-2018, 12:07 AM | #36 |
Got a package from Amain today Took me a while this evening but I got it all installed finally! In no particular order: Here we have the Vader Skid plate, which is much more low profile than stock and had a really neat internal screw setup for holding revo rod ended links. Also got a new side plate and receiver box since i had stripped out the ones that came with the truck. The spares that were in this kit shown here, I replaced everything internally except for the locker bearings cause I recently replaced those. Hard to make out, but thats an aluminum Samix motor plate with sorta integrated heat sink. Heres the beautiful Vanquish Transmission case and the SSD Steel driveshafts which both run smooth like buddah! Other side of the SSD driveshafts All in all a bunch of nice parts, if I end up getting anything else I may get the Vanquish gear protector if they ever go back in stock. |
Rek's Scale Trail Honcho - Similar Threads | ||||
RC4WD Trail finder 2 Axial SCX10 Honcho Rusty Bug honcho wraith at Durian Loop Trail | boolean21 | Scale Videos! | 0 | 04-06-2014 09:08 AM |
RC4WD Trail finder 2 Axial SCX10 Honcho Rusty Bug honcho wraith at Durian Loop Trail | boolean21 | Scale Videos! | 0 | 03-24-2014 05:02 AM |
Trail Honcho - Scale Crawl, First Run | ModTrialsRider | Videos! | 4 | 03-16-2012 01:04 AM |
Scale Trail Run 1-23-11 with a Cherokee and a Honcho | 801RYAN | Scale Videos! | 10 | 01-25-2011 09:34 PM |
