Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial SCX10 II
Thread: ProLine 66 Bronco (Deadbolt) body on 10 II Kit?
Old 01-20-2019, 08:06 AM   #1
Default ProLine 66 Bronco (Deadbolt) body on 10 II Kit?
Does anyone know if ProLine's 66 Ford Bronco body meant for the OG deadbolt will fit the 10II kit version? I'm thinking specifically of the kit clearance for the kit transmission. The bronco interior is a lot deeper and looks like it would probably interfere, I'm wondering if anyone knows one way or the other.
Thanks!
LCJP is offline   Reply With Quote
Old 01-20-2019, 08:20 AM   #2
Default Re: ProLine 66 Bronco (Deadbolt) body on 10 II Kit?
I tried to used this shell on mine. It will fit if you have aftermarket sliders, the built in receiver box is right where the seats are on the bronco shell. You can cut the box off the slider and figure out another place for the receiver too.
jason02ws6 is offline   Reply With Quote
Old 01-20-2019, 08:21 AM   #3
Trans clearance didn’t appear to be an issue, just the receiver box I mentioned above.
Old 01-20-2019, 11:57 AM   #4
Awesome thanks for the info that's a big help!
Old 01-25-2019, 11:22 AM   #5
I mounted mine by cutting the floor in a few spots.
Downforce is offline   Reply With Quote
Old 02-10-2019, 04:41 AM   #6
I'm mounting mine right now. Cutting the drivers floor out and boxing it back in with scrap lexan and super glue before paint.
Also need to tweak the sides with a heat gun and straighten them out to clear the sides, won't be running sliders with it, just for a clean look. Does fit without tweaking but will be a pain stretching the body over the sides when putting the body back on. Resting on top is a 1/4" too high for my tastes.
Does take some tweaking but not bad overall. Perfect ride height for me has the body resting on the trans, using rbk.
Xx Losungen xX is offline   Reply With Quote
Tags
bronco, deadbolt, kit
ProLine 66 Bronco (Deadbolt) body on 10 II Kit? - Similar Threads
Proline Bronco Body Help Bryan-S Paint and Body 1 04-08-2016 04:46 PM
RC4WD cms kit with Proline Bronco body 94smasher Axial Wraith 4 04-14-2015 05:46 PM
Trying to mount my proline bronco on my ax10 deadbolt mbrennan Axial AX10 2nd-gen 5 03-26-2015 04:34 PM
PROLINE Bronco body dirttrackdemon93 Axial SCX-10 6 03-21-2010 08:21 AM
