Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial SCX10 II
Thread: Aftermarket Performance Chassis Options
Old 10-17-2018, 12:42 PM   #1
Moderator
JatoTheRipper's Avatar
Default Aftermarket Performance Chassis Options
I have a set of new, built-up SSD Diamond Pro axles at home. I bought them to put on an SCX10 II kit, but then I built that as-is. So now I need a home for the SSD axles.
I know ToyZuki exists and it's quite tempting, but it is also very expensive.
I'm looking more for a something like the ToyZuki rather than plain frame rails. I mean frame rails, alone, don't offer much improvement. But I'm open to options. What other options are out there?
Old 10-17-2018, 03:03 PM   #2
Default Re: Aftermarket Performance Chassis Options
You could consider a GCM scale trans conversion in the Axial frame rails. It is a pretty significant change from stock and provides you with one hell of a drivetrain, option to run a scale motor, and overdrive the front axle. I have built a couple now and am VERY happy with how it all works together. Just something to consider!
LSXGMC is offline   Reply With Quote
Old 10-17-2018, 04:23 PM   #3
Very glad you've asked tis question. I'm itching to build a Class 2 truck and was also looking at a good chassis. I do have a GCM Transmission and was just going to get some Axial rails, but just wondered what else was out there...
neilus is offline   Reply With Quote
Old 10-18-2018, 09:11 AM   #4
Bowhouse RC makes a mount to correct the transmission orientation, perhaps that combined with some kind of motor flip to put the motor into the battery tray area would change things up even more?
Sneetches is offline   Reply With Quote
Old 10-18-2018, 10:04 AM   #5
The Scale Shop also makes aftermarket frame rails I believe.
Old 10-18-2018, 10:11 AM   #6
Just announced a few minutes ago....and Axial 10.2 raw builders kit.
Axial Racing - SCX10II Raw Builders Kit
bilinvic is offline   Reply With Quote
Old 10-18-2018, 10:51 AM   #7
You're a Venture fan now...there's always that builder's kit too.
2mtech is offline   Reply With Quote
Old 10-18-2018, 10:57 AM   #8
Slow is the new Fast
smog's Avatar
Too perfect! Haven’t opened the link, but looks like you get just the bones.
It’s a great day!
smog is offline   Reply With Quote
Old 10-18-2018, 11:40 AM   #9
got a link for this scale trans conversion? I want overdrive!! thanks
intheworks is offline   Reply With Quote
Old 10-18-2018, 11:43 AM   #10
Canada site:
http://www.gcmracing.ca/viewitem.php?productid=437
US site:
http://tinytrucks.com/viewitem.php?productid=384
Old 10-22-2018, 11:15 AM   #11
Moderator
Good point! I always forget about GCM.
I'm not familiar with this piece, but it sounds too much like a stock SCX10 II for me.
I could go that route, but I'd rather something more performance oriented than a stock SCX10 II.
True, but I'm not sure how the axles would work on the Venture chassis - in terms of gear ratios. Good thought though!
Old 10-22-2018, 11:32 AM   #12
The Crawl Space makes a kit that flips the motor on the SCXII kit trans way up front and a high clearance chassis with better link geometry.
I'm still working on getting my motor flip installed but everything fits great so far and really changes the weight distribution. The motor flip kit and chassis can be had for less than $70.
svt923 is offline   Reply With Quote
Old 10-22-2018, 11:40 AM   #13
That's exactly what I was thinking of in my post.
Old 10-22-2018, 09:12 PM   #14
This. The Game Changer chassis is a killer chassis and has racked up a lot of wins at the local and national level.
Almighty Malach is offline   Reply With Quote
Old 10-23-2018, 11:08 AM   #15
Moderator
I just checked out The Game Changer chassis and motor flip kit. I'm not a fan of either. The chassis looks like it borrowed heavily from ToyZuki, but offers less adjustment holes. And the motor flip kit is FDM 3D printed and it looks like low quality garbage.
Still looking for more options.
Old 10-23-2018, 02:22 PM   #16
Brazin hi low chasssis, also has a option for a toyzuki motormount punten front!
Sjonnie82 is offline   Reply With Quote
Old 05-08-2019, 09:15 AM   #17
Did you ever decide on a 'performance' chassis?
Old 05-11-2019, 12:47 PM   #18
I have a Team GSpeed c1v1 chassis and Team Garage Hack's T210 trans on the way. Both can be seen at either vendor's website. A set of black VP Rock Jocks built and waiting for a home. I'm ready to step up my game with the next build.
TrailDawg362 is offline   Reply With Quote
Tags
frame, performance, scx10, toyzuki, upgrade
Aftermarket Performance Chassis Options - Similar Threads
Aftermarket chassis options rcdriftmasterj Axial SCX-10 5 06-11-2016 06:23 AM
Aftermarket trans options? K1llerRC Axial SCX-10 11 10-25-2011 08:50 PM
CR-01 Aftermarket chassis options. Nonsonic Tamiya CR-01 0 04-01-2010 11:34 AM
Aftermarket options... braceysdad Losi Micro-Rock Crawler 92 02-28-2010 06:32 AM
Aftermarket CVD Options JasonJones Team Losi Comp Crawler 33 08-03-2009 09:09 PM
