06-17-2019, 01:11 PM | #1 |
Newbie Join Date: May 2019 Location: CALGARY
| SCX10 ii RTR Kit - Scale door handles
Hi Team! So the RTR kit comes with a bag of spare bits, including a set of spare door handles. They look to have holes already indented on the door to make it an easy process to line up, but it doesn't appear to come with whatever hardware is needed for the inside of the door (Like a way to keep them on/in). I'm wondering if anyone has used these, and what you had to get in order to keep them on? I assume just some kind of pin, but they look to be a bit farther out, so its almost like you'd want a couple of washers or something as well to make sure they hold tight... Anyways! thanks in advance, and hopefully someone here has the answer. |
06-17-2019, 05:10 PM | #2 |
| Re: SCX10 ii RTR Kit - Scale door handles
Usually a O ring goes in behind a body clip.
06-17-2019, 07:06 PM | #3 |
Rock Crawler Join Date: Jan 2019 Location: Calgary
Red rubber o-ring and mini body clip are the standard attachment. Could probably cut an elastic or hair band, wrap it around the post and feed it through the hole as well, really anything would work.
06-18-2019, 08:36 AM | #4 |
Rock Crawler Join Date: Mar 2013 Location: Waukesha
I’ve shoe goo’d them on from the inside. If your riding walls though they will eventually pull out. Sent from my iPhone using Tapatalk |
SCX10 ii RTR Kit - Scale door handles - Similar Threads | ||||
JK door handles | panhndl | Axial SCX-10 | 2 | 07-18-2015 07:42 PM |
Axial JK Scale Partz, Grill, Tail Lights, Door Handles, Gas Cap | Krawler Konceptz | Axial SCX-10 | 32 | 07-17-2014 08:32 PM |
Scale Door Handles And Gas Caps | Krawler Konceptz | General Scale Talk | 5 | 01-28-2013 01:20 PM |
Door Handles | FLB | Scale Accessories | 33 | 08-15-2011 12:14 PM |
who sells door handles | jessejoe23 | Paint and Body | 4 | 08-10-2011 07:46 AM |
