12-01-2017, 01:34 PM | #1 |
Quarry Creeper Join Date: Apr 2011 Location: Germany
| Customizing my SSD Pro44 axle
Hi all! I got my Pro44 axle a few days ago and I really love the scale look and apperance! It looks a lot like the Salisbury axle on my old LandRover, so I had to buy one That`s how it looks like after tearing the box appart: and, of course, some extra love: So far, nothing new here. But I wanted to detail the axle a little bit more to the looks of the real one. I like the small end caps on the Pro44 over the standard lockouts of the AR44 axle, but I think we can get a step further and mask the end cap / bearing holder as a brake drum. That`s what the original looks like: And this is what I came up with: Brake drum assembly: Drum dismantled: Hub carrier and brake pads: Hub and carrier w/o brake pads (this is the replacement for the end cap / bearing holder): Brake pads: Fast forward to today: delivery from shapeways! Last edited by Stollenritter; 12-02-2017 at 07:52 AM. |
12-01-2017, 01:37 PM | #2 |
| Re: Customizing my SSD Pro44 axle
Very cool.
12-01-2017, 02:36 PM | #3 |
Rock Crawler Join Date: Aug 2007 Location: Philadelphia
That's awesome. One day I'll learn 3D modeling. It has so many uses in my daily life. Can't wait to see these assembled on the axles.
12-01-2017, 06:02 PM | #4 |
Quarry Creeper Join Date: Aug 2017 Location: KY
I'd suggest looking into a 1:1 jack and maybe jack stands or at least a chunk of 6x6. |
12-02-2017, 02:47 AM | #5 | ||
| Re: Customizing my SSD Pro44 axle Thank you! Quote:
You will see pics of the assembled axle, of course, but you have to be patient Quote:
You are right, safety first! I will forward your suggestions to my wife. Maybe it isn`t to late for a christmas present | ||
12-02-2017, 04:22 AM | #6 |
Time for some close-ups and a rough mock-up brake pads and zylinder: redrilling and tapping for better fitment of the hardware (as the holes are not perfectly true): It is a tight fit, I had to remove some paint from the axle End cap with holes for the (SSD) hardware: Also tapped the flange / hub: The hardware for attaching the brakepads to the carrier and for attaching the drum to the carrier is the hardware (M2x5) which came with the axle and was meant to hold the diff cover. The diff cover will be fixed to the housing by using the extra scale hardware. |
12-02-2017, 08:30 AM | #7 |
RCC Addict Join Date: May 2015 Location: Price Twp.
Really cool design and idea. Is there something that can be done about the plastic used? It looks fake and toyish. Is it sandable or paintable with a filling primer?
12-02-2017, 11:36 AM | #8 | |
| Re: Customizing my SSD Pro44 axle Quote:
I did some sanding, but not to the point where the grainy surface is gone. Paint is from Revell (brush) and Tamiya (rattle can): | |
12-02-2017, 05:52 PM | #9 |
Dang, that's cool |
12-02-2017, 06:21 PM | #10 |
Quarry Creeper Join Date: Jun 2015 Location: Lancaster, NY
Well I'm impressed. The detailing of the brake shoes is spot on. very nice work.
12-03-2017, 11:51 AM | #11 | |
Drilled an oil peep hole for propper maintenance Axle assembled: And with wheels on: For reference: wheels are RC4WD Tango Down 1.9, tires are RC4WD 1.7 Atturo Trail Blade M/T. | |
12-03-2017, 12:25 PM | #12 |
Dass ist wirklich toll! Es seht ganz ehrlich aus... (practicing my German) Seriously awesome job. |
12-03-2017, 01:05 PM | #13 |
This is so awesome! Great work!
12-04-2017, 02:20 AM | #14 | |
Thank you, I am doing my best! Maybe I am getting lost in details, but I had to do some brake lining: 1mm welding rod ... and some clips made from 0.5mm aluminium sheet and some M1,5 left over bolts from a Losi Micro Crawler: | |
12-04-2017, 07:10 AM | #15 |
Your project is coming out most excellent. And no you are not getting lost in the details. I have brass brake drums and rotors sitting in packages waiting for my pro44 internal, I plan on following your lead on the brake lines and fine details. |
12-04-2017, 09:00 AM | #16 |
RCC Addict Join Date: Aug 2008 Location: Paulina
As I was scrolling through in awe, I was curious if there would be brake lines as well... Bravo! Great job here!
12-04-2017, 11:33 AM | #17 | ||
| Re: Customizing my SSD Pro44 axle Thank you! I am happy to share my build and even more happy you folks like it! Quote:
Thank you very much! To be honest, it looked naked without brake lines, so I gave it a try. | ||
12-04-2017, 01:27 PM | #18 |
Quarry Creeper Join Date: Feb 2016 Location: Salt Lake City
This is really cool. Not much more to say than that... really cool. It would be awesome if we could get these axle shafts with built-in link/shock mounts. If SSD or a third party would make this and rid us of the two bolts on each side, it would be an awesome final touch to what you have done. Great job! |
12-05-2017, 03:02 PM | #19 | |
Order of today: bits of paint for the brake line to hide the shiny stainless steel: Added a diff guard: The diff guard is printed in "HP Nylon" using multi fusion technology, which should offer higher quality and lesser wall thickness over the standard "strong and flexible". I am not sold on that. This part has a few issues. | |
12-07-2017, 09:29 AM | #20 |
I . could . not . resist . Little voices in my head told me: that brake will not work properly without return spring. So back to pliers and (florist) wire: Now it is time to find a nice chassis to put this axle under ... |
Tags |
brake, drum, pro44, ssd |
Customizing my SSD Pro44 axle - Similar Threads | ||||
New SSD Pro44 Axles | SSD | Axial SCX10 II | 210 | 03-10-2019 01:40 PM |
New SSD Pro44 Metal Diff Covers | SSD | Axial SCX10 II | 3 | 11-03-2017 07:00 AM |
New SSD Pro44 Axle Cases for SCX10 II - Open for Pre-order! | RPP Hobby | RPP Hobby | 0 | 10-13-2017 11:06 AM |
Ssd pro44 axle | redemon | Chit Chat | 36 | 10-07-2017 06:15 AM |
SSD Pro44? | 4RunnerKid | Axial SCX10 II | 5 | 10-06-2017 03:28 AM |
