01-11-2021, 05:37 PM | #1 |
Newbie Join Date: Jan 2021 Location: San Gabriel
| Scx10 ii jeep Cherokee
I have a scx10 ii I just got . I was thinking of adding the overdrive for crawling . Would I have to get anything with that so I don’t strip anything ? Or can it just be added to stock diff ? Sent from my iPhone using Tapatalk Last edited by Ignacio Sanchez; 01-11-2021 at 05:58 PM. |
01-11-2021, 06:04 PM | #2 |
| Re: Scx10 ii jeep Cherokee
You can add directly. I’ve found some extra weight will work wonders with the extra pull from the gears. I like brass knuckles personally. I’ve already adjusted foams(CI)and tires (pit bulls) Before gear change. Hang up and Drive |
01-11-2021, 06:48 PM | #3 |
First, Welcome to RCC! Changing to an OD front gear will only help you climbing and will hurt everywhere else. On the other hand added weight will help in most every situation. |
01-11-2021, 11:04 PM | #4 | |
| Re: Scx10 ii jeep Cherokee Quote:
Thanks . And what do you mean hurt everywhere else ? What does it mess up ? Yah I was thinking of getting some brass parts as well Sent from my iPhone using Tapatalk | |
01-11-2021, 11:14 PM | #5 | |
In your option, does it mess with anything else when you install the OD ? Yah for sure gonna get some brass parts on there I was looking at the knuckles and the diff cover . Just was thinking if i switch one part to metal do I have to switch all plastic parts to metal as well Sent from my iPhone using Tapatalk | |
01-12-2021, 04:40 AM | #6 | |
What he says is when the fronts turn faster, you will suffer on straight ahead trailing. OD is great for crawling and climbing, not going fast on trails Hang up and Drive | |
Scx10 ii jeep Cherokee - Similar Threads | ||||
My SCX10 II Jeep Cherokee Kit | CT Yankee | Axial SCX10 II | 1 | 11-19-2018 12:23 PM |
Almost done the kit scx10 2 Jeep Cherokee | Exiwolfman | Axial SCX10 II | 7 | 12-25-2017 03:30 AM |
SCX10 Jeep Cherokee | Bissett | Newbie General | 17 | 11-06-2015 10:43 AM |
