Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial SCX10 II
Thread: 17mm hex ?
Old 10-27-2021, 07:12 AM   #1
Default 17mm hex ?
Can anyone tell me a 17mm hex that will fit the AR44's? Id prefer one that does add width... Thanks!
Lou
TK421 is offline   Reply With Quote
Old 10-27-2021, 07:25 AM   #2
Default Re: 17mm hex ?
Are you looking for a 12mm to 17mm adapter?
Like this?
https://www.amainhobbies.com/hot-rac...4aAiT_EALw_wcB
Sent from my SM-G975U using Tapatalk
SCX10 JK is offline   Reply With Quote
Old 11-02-2021, 04:10 PM   #3
I was looking for just the hex, not a conversion. I was told the the Traxxas Slash 17mm hex conversion will bolt up. I am borrowing some from a friend to see if this is actually the case...
Lou
17mm hex ? - Similar Threads
hex adapters for 17mm hex. littlemel Formula Offroad 1 10-01-2013 12:31 PM
17mm hex wheels Jukis Tires and Wheels 2 09-02-2012 02:20 AM
wheels? need a 17mm hex. newblnc Superclass Crawlers 2 05-29-2012 07:39 AM
17mm Hex with 8mm ID? run2jeepn General Crawlers 3 09-14-2009 06:11 PM
