04-08-2020, 03:07 AM | #1 |
Newbie Join Date: Jul 2014 Location: norway
| 48P vs 32P
Hey. I have no ide what the diffrence is betwee a 49P and a 32P pinion. Can I change the stock pinion gear 48P 14T to a Pinion gear 32P 11T ? Or do I have to change the spur aswell. |
04-08-2020, 03:13 AM | #2 |
Rock Crawler Join Date: Mar 2019 Location: Terrassa
| Re: 48P vs 32P
48P quieter, 32P more durable |
04-08-2020, 03:40 AM | #3 |
| Re: 48P vs 32P
Okay! Great! Then 32p it is. Tnx so much |
04-08-2020, 05:45 AM | #4 |
Rock Crawler Join Date: Dec 2005 Location: Marietta
| Re: 48P vs 32P
The spur gear is 32P so you don't have the option of using a 48P pinion gear.
04-08-2020, 07:00 AM | #5 |
RCC Addict Join Date: Feb 2016 Location: Princeton, North Carolina, USA
| Re: 48P vs 32P
Really basically, pitch is an expression of teeth per inch on a gear. On a given gear diameter, 48p has more smaller teeth while 32p has fewer larger teeth. To themountain's point, 48p was quieter running but tended to be fragile, 32p is stronger but you tend to get more mesh noise. Like GA Dawg said, the 48p designation of the pinion in the SCX10 III manual is a misprint as both the pinion and spur are 32p. |
04-08-2020, 07:15 AM | #6 |
| Re: 48P vs 32P
Good info has already been passed along but here is a visual reference to show the differences: 16T 48P pinion next to a 16T 32P pinion |
04-08-2020, 09:04 AM | #7 |
| Re: 48P vs 32P
Tnx all! Great help. I really like the new scx10III But think it needs to be slower in first gear.
04-08-2020, 09:16 AM | #8 | |
| Re: 48P vs 32P Quote:
32p 11t Axial pinion - AX30722 12t - AX30723 13t - AX30724 | |
04-21-2020, 11:25 AM | #9 | |
Newbie Join Date: Feb 2020 Location: Hilton Head
A bit of a fiasco when ordering. The supplied 14t would not fit the 5mm shaft on my Tekin Roc412HD, so I ordered a 14t 48p (per the manual) with a 5mm shaft. Needless to say, the 48p would not nesh with the spur. I then ordered a 32p 14m with a 5m shaft and all was fine until I decided that I wanted to slow her down a bit. Anyway, 4 pinions later I wound up with an 11t 32p 5mm bore and am really happy with the final result. | |
07-15-2020, 10:16 PM | #10 | |
Newbie Join Date: Jul 2020 Location: New Hope
48P vs 32P - Similar Threads | ||||
48p or 32p ??? | Frank211 | Newbie General | 25 | 11-22-2018 06:55 PM |
32p to 48p spur | Crawlininga | Axial SCX10 II | 15 | 11-05-2016 07:16 AM |
Converting 48P to 32P | joe.bielski | Newbie General | 16 | 08-06-2015 10:38 AM |
I want to use 32p instead of 48p on my TLT | mikesativa | Newbie General | 2 | 12-05-2006 05:23 AM |
