06-25-2021, 03:50 AM | #1 |
Newbie Join Date: Jun 2021 Location: HONG KONG
| oil leakge problem with stock SCX10 iii shock absorber ?
I have been told that the stock shock absorbers need be replaced because of such problem. Would like to hear some feedback from owners.
06-25-2021, 04:01 AM | #2 |
RCC Addict Join Date: Sep 2010 Location: Apollo Pa
| Re: oil leakge problem with stock SCX10 iii shock absorber ?
Every Axial shock leaks eventually, I don't use them, when I built my 10.3 I used Trx4 shocks. Sent from my SM-N981U using Tapatalk |
06-25-2021, 04:42 AM | #3 |
| Re: oil leakge problem with stock SCX10 iii shock absorber ? |
06-25-2021, 04:56 AM | #4 | |
| Re: oil leakge problem with stock SCX10 iii shock absorber ? Quote:
Sent from my SM-N981U using Tapatalk | |
06-25-2021, 06:41 AM | #5 |
RCC Addict Join Date: Jan 2019 Location: Corvallis, OR
eBay is a good source for Trx4 shocks, if you watch you can usually find a set of 4 for around $45 + shipping. I’ve been happy with the element enduro bronze shock set, they are $76.50 for the set from amain or rpp I believe. They come with pivot balls, and have springs that are geared towards an scx10.2 type rig. A lot of people seem to like traxxas big bore shocks, I haven’t used them personally. Most people modify the shock cap to accept a standard rod end, and they utilize short mini t springs. I believe dlux fab sells pre modified sets with springs for a very reasonable price. Search for dravtechs if you want to see more on those. Sent from my iPhone using Tapatalk |
06-25-2021, 10:58 AM | #6 |
Quarry Creeper Join Date: Jul 2020 Location: Lincoln
I was using the stock Axial shocks, which no longer have any oil. Started leaking about a month later after building. Didn’t try any green slime though. Swapped to TRX4 shocks, but using the Axial springs. Sent from my iPhone using Tapatalk |
09-29-2021, 08:43 PM | #7 |
Newbie Join Date: Sep 2021 Location: port orchard
I have heard there is an advantage to using a shorter shock for the scx10 iii bronco... if that is true how do I even know how long the stock ones are and where do I purchase new ones... Fred (newby)
09-30-2021, 06:55 AM | #8 | |
Rock Crawler Join Date: Dec 2018 Location: Ontario, Canada
Stock shocks on the SCX10iii Early Bronco are 100mm long. You could confirm this by using a measuring device such as a ruler. You can purchase shorter 90mm shocks from almost anywhere that sells RC parts, such as: https://www.amainhobbies.com/search?s=90mm+shocks | |
oil leakge problem with stock SCX10 iii shock absorber ? - Similar Threads | ||||
Lubricant Or Shock Absorber Oil | The_Hulk | Newbie General | 5 | 01-23-2021 06:25 PM |
stock shock oil | 83trekker83 | Traxxas TRX-4 | 16 | 05-26-2019 05:01 AM |
stock shock oil | Hobbezco | Vaterra Ascender | 1 | 07-08-2016 12:49 PM |
Problem putting the shock cap back on after changing oil | Skadar | Axial Wraith | 5 | 01-03-2012 10:50 AM |
Stock WK shock oil | JpSonoma | HPI Wheely King | 1 | 05-19-2007 06:25 PM |
