04-22-2022, 07:06 PM | #1 |
Newbie Join Date: Oct 2021 Location: Springfield
| Scx 10.3 axles
Has anyone tried putting on the ar45 portals a wraith 1.9 replacing the ar44. Will all the links line up without readjusting them?
04-22-2022, 07:18 PM | #2 |
Quarry Creeper Join Date: Dec 2012 Location: Toxaway
| Re: Scx 10.3 axles
Haven't tried it but have both of those on my bench. I'll take a look at the basics and see but I would say probably a pretty good chance Sent from my SM-G975U using Tapatalk |
04-22-2022, 07:26 PM | #3 |
| Re: Scx 10.3 axles
They look very similar in width, I couldn't take it out of package to line it up with my 1.9, while I'm at it will the dig tyranny line up with the wraiths?
04-22-2022, 07:34 PM | #4 |
Rock Crawler Join Date: Mar 2021 Location: Santa Barbara
| Re: Scx 10.3 axles
I put a 10.3 rear on a truck with 10.2 links... they're close enough. I don't remember if I had to adjust them at all, but if I did it was very minor. I use 10.2 links with capras without having to do a ton of adjustment, and they're way different.
04-22-2022, 07:44 PM | #5 |
| Re: Scx 10.3 axles
Thanks, I have both the Spawn and 1.9 and their links are completely different lenths
04-22-2022, 07:45 PM | #6 |
| Re: Scx 10.3 axles
Yup just measured link mount centers basically 3" on both and shock mount center 4" they maybe very minutely different but no issue should happen in mounting except for upper link that would probably need to be custom because the ar44 is center diff vs offset. Well the lower links from the wraith 1.9 will work fine the upper rear might as they have similar mount positions front axle will need different length upper and panhard and steering link. So you will need to do some custom link work in the front it looks like. Sent from my SM-G975U using Tapatalk Last edited by SCX10 JK; 04-22-2022 at 07:55 PM. |
04-22-2022, 07:52 PM | #7 |
| Re: Scx 10.3 axles
Looks like just the front is offset on the 45's
04-22-2022, 07:59 PM | #8 |
| Re: Scx 10.3 axles Yeah but you can switch upper front link to other side with the ar45 axles but the kicker is the front steering link is stock ar45 but the drag link and panhard will be the hard part but should be very doable. Sent from my SM-G975U using Tapatalk |
04-22-2022, 08:04 PM | #9 |
| Re: Scx 10.3 axles
Thanks for the info
04-22-2022, 08:12 PM | #10 |
| Re: Scx 10.3 axles |
04-22-2022, 08:16 PM | #11 |
04-22-2022, 11:21 PM | #12 |
04-23-2022, 06:19 AM | #13 |
| Re: Scx 10.3 axles
Not Spawn links, I have 1.9 wraith and want to put ar45 portals on it. I mentioned I have both Spawn and 1.9 and links are different lenths
