06-05-2022, 05:37 PM | #1 |
Newbie Join Date: Mar 2019 Location: PNW
| Would 1.55s fit the SCX10 III straight axles?
I'm planning a 10.3 build but I want to ditch the massive tires and portal axles. I'm drawn towards 1.55" wheels and tires. Is anyone else running this size on their 10.3 and will they clear the front knuckles on the straight axle?
06-05-2022, 07:55 PM | #2 |
| Re: Would 1.55s fit the SCX10 III straight axles?
It'll depend on the wheel and offset. If they are the type with a separate inside beadlock ring, you might well run into trouble. But if you run something like the RC4WD deep-dish spoke wheels, they not only lack that ring but also have the right offset to be no problem. Take a look at this image to see what I mean: https://www.rc4wd.com/ProductImages/Z-W/Z-W0284-7.jpg Post up what wheels you are considering. A wider hex can be used to help clear the knuckle. Also - based on the image below of the SCX10.3 straight axle, they don't have a really protruding knuckle: Last edited by durok; 06-05-2022 at 07:59 PM. |
06-05-2022, 09:02 PM | #3 |
RCC Addict Join Date: Jan 2019 Location: Corvallis, OR
Fwiw I mounted stock element 1.55’s on ar45 straight axles without issue. Sent from my iPhone using Tapatalk |
06-05-2022, 09:06 PM | #4 |
Quarry Creeper Join Date: Jan 2021 Location: in the Canyon
AR45 straight, stock hex, fitted with the OE plastic 1.55 beadlock from an Element Knightrunner. Fits just fine. |
06-06-2022, 08:04 AM | #5 |
Thank you guys! After several 10.2s this will be my first 10.3. I can't wait to build it!
Would 1.55s fit the SCX10 III straight axles? - Similar Threads | ||||
Axial SCX10 III Standard Straight Axle | MrCataract | Element RC 1/10 Enduro Trail Truck Sendero | 2 | 06-02-2021 08:56 AM |
