07-16-2011, 05:07 PM | #1 |
Quarry Creeper Join Date: Jul 2009 Location: israel
| slipper clutch
i was wondering if in the wraith the slipper is stop you from keep crawl sometimes? and there is any way to cancel the sliper clutch?i want to know if i can cancel it for my friend ax10 to? |
07-16-2011, 05:55 PM | #2 |
RCC Addict Join Date: Mar 2010 Location: Yelm
Crank that sucker down tight. No more slip |
07-16-2011, 09:31 PM | #3 |
It's exactly like the rest of the Axial transmissions. It comes with a slipper clutch, adjust as needed or use the slipper eliminator parts to delete the slipper If you want.
07-17-2011, 03:18 AM | #4 |
07-17-2011, 06:16 AM | #5 |
Rock Crawler Join Date: Aug 2009 Location: milton,wv
take the wrench and tighten the nut on the spring and you wont have a slipper anymore
07-17-2011, 10:35 AM | #6 |
sheesh, its free to tighten it up. you tighten it up nice and tight you wont be able to slip it, tighened mine up and even full speed rev. to WOT forawrd it wont slip running 3s lipo and a HH 20t handwound motor, and just kissed my drive shaft good bye!
07-17-2011, 04:10 PM | #7 |
RCC Addict Join Date: Aug 2007 Location: Burbank
With all the tires and radical motors on the market it might be smart to leave it a tad loose so not to start ripping parts out. Remember, there has to be a weak link that can get replaced easily.
07-17-2011, 08:42 PM | #8 |
07-17-2011, 10:07 PM | #9 | |
Really? I have a spacer behind one of my transmissions without the slipper to take up the room. Never looked to see if the top shaft was a different length vs. the one with slipper. Either way, a slipper is a good idea especially once you want more power. | |
07-18-2011, 09:35 AM | #10 | |
With the plastic eliminator (P/N AX80009) you need the AX30197 shaft. It has the flats on it for the eliminator. | |
