07-24-2011, 08:35 AM | #1 |
Rock Crawler Join Date: Jan 2008 Location: Eveleth
| Wraith with New Roof Panel
Got my Wraith the other day and before running it changed the servo for a JR8711. Also added a CC BEC and lowered the ride height. Peeled the majority of the stickers off and made a new roof panel. I went to a local hardware store and found some thin white kydex, nice big sheet only cost me $1... A few pics... I have yet to take it on the rocks and give it a shakedown run. I did noticed that bashing around in the grass and parking lot the stock motor gets quite warm. I think a drop in pinion size will be in done to remedy the heat. |
07-24-2011, 04:36 PM | #2 |
Was able to get some running in today. Top speed is impressive and it crawls pretty decent too. Going to re-gear to a 15t pinion, that should help with the motor heat and make it crawl better too. Ordered the Vanquish ti steering link, the plastic one flexes way too much. Also ordered the white styrene hood from Dinky R/C, hoping to add a cowl type hood scoop and maybe a shroud in front of windshield area. Should have time this week to paint the side panels.... Will post pics of progress... Thanks for looking... |
07-29-2011, 04:39 PM | #3 |
Got the Vanquish link installed and painted the side panels. I cut a piece of kydex to fill in the empty area on the back of the rig. Shot the side panels with a silver base topped with white. The Dinky R/C hood showed up yesterday, trimmed up and fitted. Will be cutting the headlight area open at a later date, have a fun run this weekend. Went to change the pinion to a 15t and it would not mesh with the 80t spur. Ended up going with a 16/87, the final drive is close to where I was hoping for with 15/80. A few pics.... |
07-29-2011, 06:47 PM | #4 | |
Quarry Creeper Join Date: May 2010 Location: Los Angeles
07-29-2011, 07:13 PM | #5 |
I have a couple of action figures, sorry no stormtrooper, one is a bit short the other a froghair too tall. I have just begun making this truck my own. Many more changes are in the works... Thanks for the compliment... |
08-01-2011, 08:28 AM | #6 |
RCC Addict Join Date: May 2010 Location: The heart of the south
Unbelievable how nice this looks in plain white.
08-01-2011, 04:43 PM | #7 |
Pebble Pounder Join Date: Apr 2006 Location: griswold
How did you lower it that much?
08-02-2011, 07:20 PM | #8 |
I flipped the lower mounts on both axles. In the rear I flipped the upper shock mount too and remounted the shock in stock location. The front shocks are laid back closer to the interior, 3rd hole. I also ran the spring adjusters all the way to the top of the shocks. It handles much better now and is less prone to rolling. Also the gear change to 16/87 is much closer to where I was wanting it. Motor runs alot cooler now on 2s. |
08-06-2011, 05:56 PM | #9 |
| Updates...
Well I had some more time to work on my Wraith. I relocated the tail lights to the upper braces of the rollcage. I just had to drill a 3/32" hole and countersink it a bit with an 1/8" bit. It did not seem to weaken the tube work any. I also added a Reign R/C whip antenna and a fire extinguisher. The zipties holding the extinguisher on also hold the tail light wires. Finally had a chance to get it out on the rocks and also a pile of agrilime. The agrilime was really hard from all the rain we have had, it was a blast running on it. The stock tires seems to work pretty well for the rocks and the hardened agrilime pile. The gear change was pretty close to where I was wanting to be, may go up 1 or 2 teeth on the pinion. Motor was cool after running for an hour or so. Here are a few pics... I still need to open up the headlight area on the hood and add my driver figure... |
08-06-2011, 09:26 PM | #10 |
Quarry Creeper Join Date: Nov 2007 Location: Fargo
Really wish I had a wraith. Running yours today was a blast.
08-07-2011, 09:38 AM | #11 |
Rock Crawler Join Date: Dec 2005 Location: Mesa
Now it doesn't look like all the others. Looks good
08-07-2011, 10:16 AM | #12 |
Thanks for the comments. I really like how the tail lights look up under the roof panel. I have seen it before on 1:1 rigs and liked the idea. I pulled the front diff cover off this morning and got rid of the ribbing, ribs are only for looks. I shot it with some black Krylon Fusion paint. Also opened up the headlight holes. Once it is all back together I will post some pics. |
08-07-2011, 11:19 AM | #13 |
Rock Crawler Join Date: Jun 2011 Location: Vancouver
nice rig man.... Do u still running stock motor with 15t/80 spur?? I was thinking to run 35t motor with 20t/80 spur, but don't know if it is gonna be to slow or not thanks |
08-07-2011, 03:00 PM | #14 |
I wanna be Dave Join Date: Oct 2007 Location: 801
That's a good looking rig!!!! I love the white and the ride height. |
08-07-2011, 05:28 PM | #15 |
| More stuff added...
I got the driver in, extended the steering wheel by 1 1/4". I used a section of carbonfiber arrow that I had laying around. Had to relocate the fire extinguisher so the driver was more comfortable. Made a tonnue cover out of vinyl, will make it tough to change the battery. The vinyl is captured by the side panels and just draped over the front crossbar behind the seats. Opened up the headlight holes on the Dinky R/C hood and found some decals for the grille and light trim. As for the gearing question. The 15/80 would not mesh so I am geared at 16/87. Still running the stock motor. Once the stock motor gives up on me I will change it for a Traxxas 21t Emaxx motor. Some pics from todays bashfest... Thanks for looking... |
08-07-2011, 06:01 PM | #16 |
Pebble Pounder Join Date: Jan 2005 Location: Minot
Nice shots of bashfest Dave. Rigs looking good
08-07-2011, 07:03 PM | #17 |
The last 2 shots, Tony must have driving, " Pinch It! "
08-07-2011, 07:17 PM | #18 |
08-08-2011, 05:32 AM | #19 |
Thanks for the compliments guys. For being just a pile of agrilime it sure can be alot of fun and challenging as well... |
08-11-2011, 06:52 PM | #20 |
| Updates...
I picked up a set of Pitbull Rockbeasts mounted on Axial black chrome wheels. This should help with the low speed crawling, no more tire squealing for me... Some pics... Thanks for looking... |
