09-02-2011, 09:42 AM | #21 |
09-02-2011, 07:09 PM | #22 |
Ultimate RC Decals Join Date: Aug 2005 Location: San Antonio
minor set back... almost burned the wraith down!! FXR decided to let the smoke and flames out... i have now went to a Holmes BRXL. |
09-02-2011, 07:29 PM | #23 |
Pebble Pounder Join Date: May 2011 Location: Vacaville
Wow that could have been a lot worse Ccant wait to see some more pics man Justin |
09-03-2011, 12:05 PM | #24 |
Rock Crawler Join Date: May 2010 Location: Albuquerque
09-03-2011, 12:20 PM | #25 |
09-04-2011, 12:41 PM | #26 |
small update.. fabbed up a plate today for the rear area. now i have i nice spot to carry some scale goods. also moved the lights up onto the plate. i was going to do through the panel mod with them but i figured this would easier in case i have to remove the panels. |
09-04-2011, 10:10 PM | #27 |
Rock Crawler Join Date: Jan 2008 Location: Cotati
09-05-2011, 03:50 PM | #28 |
Had a chance to run it today.. With me still looking for some used SLW v1's I have the TSL's mounted on mixed match wheels. and the front wheels are starting to grow on me as far as looks. may run those instead. small clip.. |
09-05-2011, 04:05 PM | #29 |
RCC Addict Join Date: Dec 2010 Location: middle,tn
pretty cool ric..just a tip to all that dont know..when you jump release the throttle while in the air unless you want to correct you levelness..holding throttle on jumps is what bust xvd's,axle shafts,and driveshafts..i know this from shortcourse racing..those parts take alot of shock when you land and they are spinning wide open under power..anyways thats thing is quick and i'm digging the mix match wheels |
09-05-2011, 04:06 PM | #30 | |
what material did you use on this i think its aluminum..but not sure .i like it | |
09-05-2011, 04:35 PM | #31 | |
thanks for the tips. yes it's aluminum sheet that i picked up awhile back for some other builds. do know the exact thickness, thinking .020, but it's real thin. i can trim it with scissors. | |
09-05-2011, 07:54 PM | #32 |
ATI wheels fo sho! Does SLW hubs bolt up ? |
09-05-2011, 08:00 PM | #33 |
09-05-2011, 08:10 PM | #34 |
09-05-2011, 08:54 PM | #35 | |
DOOH!!! Join Date: Feb 2007 Location: AZ
Wraith's looking good!! | |
09-06-2011, 04:28 PM | #36 |
made some changes.. played with some styrene and made some side panels. painted them silver to see what an aluminum panel would look like before i order a set. also hacked up an old C10 body to grab the hood. gotta add a touch of chevy there... |
09-06-2011, 04:35 PM | #37 |
Looks good! Thought about painting the C10 hood on the outside too? |
09-06-2011, 05:37 PM | #38 |
09-06-2011, 05:46 PM | #39 |
Rock Crawler Join Date: May 2010 Location: San Antonio, TX
Hey Ric, those wheels look pretty damn good on there. Are you up for some Wraithing this Sunday?
09-06-2011, 05:48 PM | #40 |
sounds good. lets plan for sunday, cibolo creek. start at the bridge and crawl to RR bridge.
