09-02-2011, 09:23 PM | #1 |
Pebble Pounder Join Date: Jun 2011 Location: Central California, Pismo Beach/San Luis Obispo
| The aftermath, somethings wrong
Just took my wraith out for a pic sesh and I think something happened while climbing. I turn on the wraithand it does the first group of beeps then it goes to straight beeping. Sometime it will register and when it does the servo twitches and the throttle is delayed. The steering won't work. I'm thinking that either the servo or ESC is busted.
09-03-2011, 12:12 AM | #2 |
Quarry Creeper Join Date: Jul 2009 Location: Buffalo area
There has been A LOT of this type thing going on.... WAY too much. But on a good note, Axial will make it right. I have my sample coming Tuesday and can only pray I don't have issues like this, but I have in the past with Axial electronics. Might be the radio BD, but I have had two ESC's go bad running in spec too after only a few runs, and I doubt the servo is causing it. Sometimes its the simplest of things tho, did you try to pull out all the connectors and re-insert them to see if the contats are ok? Maybe re-bind the radio after that and do the ESC setup process again? I can't spell to save my life, but there's that electrollisis(sic) thing that happens any time you put two metals together. They are supposed to be different metals to have the greatest effects, (like a battery) but with the china-cheap alloys used to build these rtr radios, and the idea they are shipped over salt water seas makes me wonder if its causing issues like this?? Last edited by cogfounder; 09-03-2011 at 03:04 AM. |
09-03-2011, 09:44 AM | #3 |
RCC Addict Join Date: Mar 2009 Location: Chilton
My connectors were barely even in my rx when I got mine. I bumped a wire and one of them fell came out. i was taking it apart to go through everything since people seem to be having issues with stuff not being tight or it just falling out.
09-03-2011, 10:13 AM | #4 |
Quarry Creeper Join Date: Dec 2005 Location: the first state
i had this issue after i put in a new motor and servo. i just unplugged everything, then re-assembled it. its been fine since.
09-03-2011, 12:15 PM | #5 |
That's not the problem. That's happened to me and I've unplugged and replugged and got it running. Its something else this time. After unplugging and replugging its still acting up. When I plugged my winch into the RX it randomly started pulling and un spooling. So something it messed. Either the RX or the ESC
09-03-2011, 06:59 PM | #6 |
Rock Crawler Join Date: Apr 2010 Location: America
so you are using a winch with the axial radio and receiver? i thought they was only 2 channel? but anyways your servo could very well be the issue unplug the servo and see if the esc runs correctly and if you don't mind could you post a pic of the winch mounted on the wraith ive seen ur gravedigger thread and it by far is the best imo but anyway good luck with your electronics
09-03-2011, 07:06 PM | #7 |
another good point, when i upgraded my steering servo, the esc would cut out, then it wouldnt turn on. after i put in the cc bec that problem went away. i am wondering if i damaged the esc bu running the high power servo.
09-04-2011, 08:28 AM | #8 | |
Quarry Creeper Join Date: Sep 2010 Location: China
Hmm, was about to start a thread when I read this. I just got my Wraith last night and after doing all the tightening of bolts and checking connections I ran it for a bit indoors last night. It was perfect. Today, when I went to the trails, it ran well for about 10 mins, then the same thing happened. The throttle gets delayed when i full the throttle. I found out after checking that power gets cut after a while. I'm hoping it's only my battery and the lipo cut off on the esc is doing this. This on a new non upgraded stock wraith. Hope you find out what's wrong with yours. I'll try the battery theory tomorrow. | |
09-04-2011, 10:30 AM | #9 |
RCC Addict Join Date: Oct 2005 Location: rite here all along
What batteries are you guys running? On 2s I had no problems only acted up on 3s for me. I only have 2 2s pacs so I switched over to my Mamba Max and no problems now, oh yeah the 7955 also Still running the stock radio and receiver and no issues with it, will swap it out when I get tired of the chassis and swap everything on to the Boyer tuber Last edited by halfcab; 09-04-2011 at 10:33 AM. |
